How to test for tuning capacitor watts
Discussion in 'General Technical Questions and Answers' started by CAMERART, Oct 13, 2019.
  1. WA7ARK
    WA7ARK Ham Member QRZ Page
    Most hams just transmit into a capacitor to see if it arcs. If it does, it didn't have sufficient spacing between the plates.
    Arcing usually pitts and burns the plates of an air dielectric capacitor to where you have to buff out the burned spots. With a film dielectric, you are going to destroy the capacitor by blowing a hole through the film.
  2. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    This is true....I've sanded down a number of sizzled plates in my career.
  3. KA0HCP
    I would advise against testing a polyvaricon with high voltage. Any breakdown damages the dielectric, probably fatally. Test with an Ohmeter. As long as you get an 'open" then the cap should still be good.
    Yes, I would consider 5v to be low power. Follow the project specifications and you should be good.
  4. WB2WIK
    Except for really big and really good ones, which use vacuum-variable capacitors, usually motor-driven.:)
  5. VU2NAN
    VU2NAN Ham Member QRZ Page
    Hi Camerart,
    You just need to enter the power and the feedpoint impedance (assume 5000 Ω for the end fed antenna) to get the voltage at the feedpoint.
    Voltage breakdown would result in overheating or arcing.
    Nandu.
  6. CAMERART
    CAMERART QRZ Member
    Hi K,
    If you check again the link in post#1, you will see that the cap does tune between 40 and 17Mtrs.
    C
  7. CAMERART
    CAMERART QRZ Member
    Hi N,
    I recall that in 'normal' conditions a rule of thumb is 1mm for 1000V for an arc.
    5W------------7:1 transformer---------- Here's the result from your suggestion?
    So approx 1/5 MM plate gap. Does this seem correct?
    C
  8. SM0AOM
    SM0AOM Ham Member QRZ Page
    It was quite common for the larger ceramic capacitor types ("beaker" or "saucer" sizes) once found in
    MF and LF antenna matching networks.
    73/
    Karl-Arne
    SM0AOM
  9. CAMERART
    CAMERART QRZ Member
    Hi K and W,
    Re High voltage testing. I have a megger motor with no gauge, but could borrow one. How would I use one?
    C.
  10. VU2NAN
    Hi Camerart,
    Yes, that's correct.
    Nandu.
