How to solve the background noise brought by the rotator
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by BG5UZW, Nov 12, 2021.
  1. BG5UZW
    BG5UZW Ham Member QRZ Page
    I don’t currently have photos of the rotator that I’m using. These photos were taken by the producer, and the actual objects are not much different from them.
  2. W9IQ
    W9IQ Ham Member QRZ Page
    The components to the right of the power cord appear to comprise a switching power supply. That is most likely the source of the noise. I suggest you contact BG0AUB for assistance. It appears that he uses the controller for satellite work so perhaps he is not concerned with, or aware of, the noise generated on HF.
    - Glenn W9IQ
  3. BG5UZW
    I also want to use the controller for satellite work,but it not only produces noise on HF, but also produces noise on VHF and UHF...............
    I have tried to ask BG0AUB&BG0CAB for help,but they also can’t make definite judgments without seeing the real thing.
    This may be a special example.
    Anyway, thanks for your help, I will go to the roof to try your suggestions again this weekend.This really makes me tired, I have been dealing with this since the beginning of October...
  4. SWL37632
    SWL37632 QRZ Member
    That board does not appear to have typical RFI mitigation such as chokes, ferrite beads, shielding, etc., etc.
    W9IQ's comments and recommendation that you contact the maker are a good suggestion for you.
    Bill
  5. SWL37632
    SWL37632 QRZ Member
    It appears that I was writing my post when you sent your post.
    It also appears that the maker of the board is not being very responsive to you about this problem.
    If you are unable find someone to help you about this, you may need to educate yourself and mitigate this problem yourself.
    Otherwise, you may also consider purchasing a different system from a more reputable and responsive maker.
    Good luck
    Bill
  6. BG5UZW
    It's true.Thanks.
  7. SM0GLD
    SM0GLD Ham Member QRZ Page
    If this is the setup there are multiple sources of noise.
    We can see the controller board sitting in the door and the two stepper motor drivers in lower part of the box.
    All this can produce noise and needs to be filtered on all cables.
    If you are using the Ethernet interface this is also a very problematic source of noise.
  8. BG5UZW
    Now it can be basically determined that it is the interference caused by the controller
