How to reduce noise from the car engine and electricals?
Discussion in 'Mobile Radio' started by VK2MJM, Dec 20, 2014.
  1. VK2MJM
    VK2MJM Ham Member QRZ Page
    Hi,
    I have just put my FT-857d in the car and there is noise when the engine is on or the navigation/entertainment system is on. Does anyone know what I can do about that?
    Many thanks,
    Jeremy
    VK2MJM
  2. KD0CAC
    KD0CAC Ham Member QRZ Page
    More information needed , can you turn off the navigation/entertainment system & just run the engine , then the other way around , engine off key on ?
    Then some description of the noise , bands , modes etc.
    A good answer , requires a good question ;)
  3. KA9JLM
    From the other problems you have on your other 2 post, You may have grounding issues.
    Good Luck on your project.
  4. VK2MJM
    Hi,
    Thank you for your replies. No, I thought it was electricals, but it really is only when the motor is running. There is considerable noise feeding back into the radio receive.
    If it is a grounding issue, what might be the best way to ground the radio? I had simply ' installed' the radio under the passenger seat, but I can see myself having to get the mobile installation bracket and some braid and drilling holes into the passenger seat metal frame. Is that what is required? I had wondered if putting my IC-7100 into the car would require less work?
    Thanks
    Jeremy
    VK2MJM
  5. KD0CAC
    If just running , on Rx , I would think that it would be either ignition or charging system ,
    and may be getting picked up by the antenna or power wires .
    But again , more details on installation , bands etc.
    With the lack of info on your side , this should be a good place to do some checking http://www.k0bg.com/
    he hangs out here a lot .
  6. VK2MJM
    I seemed to have resolved the noise issue by applying an rf coke with the excess coax near the antenna under the bonnet and using a ferrite bead I had. Thanks
    Jeremy
    VK2MJM
  7. K8ERV
    K8ERV Ham Member QRZ Page
    Luvit when a plan comes together----
    TOM K8ERV Montrose Colo
