How to fix a problem at QRZ Logbook
Discussion in 'Logbook User Forum' started by CM6RK, Sep 19, 2020.
  1. CM6RK
    CM6RK Ham Member QRZ Page
    Hello, for a long time, I confirme contacts but at this moment, I have 10 contacts that not confirm because the contacts have problems.
    When I press at ::: Help! How do I fix this? the website not show nothing.
    Soo, how can I fix the problem to confirm ?
    Thanks for help me.
    73´s
    Roberto
    CM6RK
  2. KG5THG
    KG5THG Platinum Subscriber Platinum Subscriber QRZ Page
    Using the first one as an example, click on view, then click edit, and select receiver info. You will need to correct the information that is incorrect. In the case of the first one, ah6l's qsl said he was in the united stats dxcc 291 and not in hawaii. You would set the dxcc to the united states and save the record. If you think ah6p was in hawaii at the time of the contact, you will need to contact ah6p and ask them to change their qsl record. For the others, you just need to verify and set the correct state. The dxcc entity is already correct.
    W0AQ likes this.
  3. WN1MB
    WN1MB XML Subscriber QRZ Page
    PU2OZT likes this.
  4. CM6RK
    Hello, thanks for help me.
    I fix some contacts using your explain but what can I do with this ?
    QRZ don´t accept FLO as an US. State soo... the contact is not possible to fix by me.
    What can I do ??
    Regards
    Roberto
    CM6RK
  5. WZ7U
    WZ7U Ham Member QRZ Page
    Roberto, contact WA4JS directly via email and explain to him. His email is on his call sign lookup page. GL, 73!
  6. W1DQ
    To read "How to fix" instructions, hover your mouse arrow over "How to" ; do not click.
  7. CM6RK
    Ok, I read it... I am sending an email to this han radio people to check this problem and fix.
    Thanks!
