How to design the front end of a radio
Discussion in 'Homebrew and Kit Projects' started by KG6NEI, Jun 8, 2008.
  1. AC0FP
    AC0FP Ham Member QRZ Page
    A check of my designs (which can still be purchased today) show I always use a L-network to match 50 ohms to the input of the 1st LNA.
    Frank:)
  2. KL7AJ
    KL7AJ Ham Member QRZ Page
    There's a ton of great stuff on this, but you should start with the ARRL Handbook (almost any edition).
    A few ground rules before you start, however.
    1) GAIN is the easiest thing in the world to achieve. Anyone can build a really lousy preamp with a lot of gain. Don't go there.
    2) Noise is always a function of temperature. The lower the temperature, the lower the noise. There are two ways to keep the temperature down....low current or large mass. R.F. power transistors make great low-noise front ends for receivers!
    3) Never design a stage for maximum gain. Transistors are cheap. Design for stability...which means several low gain stages are better.
    4) Use lossless negative feedback if you can. This is a cool...but advanced...technique.
    5) Front end selectivity is a good thing.
    Have fun!
    eric
  3. AC0FP
    Modern transistors are "HotRods"
    Eric has a great point about gain. Modern transistors have a tremendous amount of gain and low noise figures available and there relatively cheap. Keeping that gain under control and maintaining stability can be a real challenge. Many times I have chosen grounded Gate JFET's (J310) for use up to and including two meters for this reason.
    Frank:)
ad: cq2k-1
