How to change End Date of Log book in Properties
Discussion in 'Logbook User Forum' started by A65DB, Feb 11, 2017.
  1. A65DB
    A65DB Ham Member QRZ Page
    I couldn't change the End Date of my log book it was expired on Dec 31 2016. in Logbook Settings-Properties.
    So I am not able to upload new logs from 1-1-2017.
    A65DB.
    UY7VV likes this.
  2. W1DQ
    I have reset the End date to 2017-12-31
    Open your logbook
    Click on SETTINGS then PROPERTIES
    Adjust End date
    UY7VV likes this.
  3. A65DB
    Thank you W1DQ...73s.
  4. KK6MF
    KK6MF XML Subscriber QRZ Page
    I have followed the instruction provide, but the date reverts to original values.
    Any suggestions?
    Thank you, Larry B.- KK6MF
  5. W1DQ
    It is a matter of technique:
    Click in the date box to launch calendar
    Select Year
    Select Month
    Click on Day in month
  6. KK6MF
    Wow, who would have ever guessed? Thank You, Larry B. - KK6MF
    PS, I'm not sure if the ? symbol works correctly? Pushing it does nothing. Hovering on it, put a string of output on the screen and beyond. I could only get a glimpse of it.
  7. AE5OX
    AE5OX Ham Member QRZ Page
    I lost all my lodged calls,I only have two calls to show on my lodge book how do I retrieve my calls? Ae5ox 73s
  8. W1DQ
    On October 28, 2019 you deleted your logbook and lost all its contents.
    The date range of your logbook is currently set at Start 02-03-2010 and End 11-13-2019. You need to adjust the dates as required. Open your logbook, click on SETTINGS then PROPERTIES.
    You need to import your log's back-up ADIF file or manually enter the lost QSOs'
