How do I change the time?
Discussion in 'QRZ Site Community Help Center' started by CS7BKJ, Sep 21, 2025.
  1. CS7BKJ
    CS7BKJ Ham Member QRZ Page
    Good morning:
    How can I change the time? I enter an hour but when I record it always appears one hour less.
    Thanks
    [Good morning:
    how can I change the time? I enter a time, but when I record, it always shows an hour less.
    Thank you.]
  2. AD5HQ
    AD5HQ Community Expert Volunteer Moderator Volunteer DX Helper QRZ Page
    Ok, I'll ask - change the time on what?
  3. CS7BKJ
    por exemplo, agora em Lisboa são 19 horas e 51 minutos mas aparece UTC 18 horas e 51 minutos, uma hora antes
  4. KX0DW
    KX0DW QRZ Lifetime Member #212 Volunteer Moderator Volunteer DX Helper Platinum Subscriber Life Member QRZ Page
    Se estiver a falar da hora nos fóruns do QRZ, então vá aos fóruns (como este que está a ler agora), clique no seu indicativo de chamada no canto superior direito do ecrã, selecione "Preferences" e, em "Locale", verá onde pode selecionar o seu fuso horário local.
    Se estiver a falar da página inicial do QRZ, essa hora está definida para UTC e, tanto quanto sei, não pode ser alterada.
    If you're talking about the time in the QRZ forums, then go to the forums (like the one you're reading now), click on your callsign in the upper right corner of the screen, select "Preferences", then under "Locale" you will see where you can select your local time zone.
    If you're talking about the front page of QRZ, then that time is set for UTC and can't be changed to the best of my knowledge.
    KP4SX likes this.
