Homebrew Kenwood TS-850 CAT Cable
Discussion in 'Homebrew and Kit Projects' started by VE3TMT, Nov 20, 2018.
  1. VE3TMT
  2. KA9JLM
    I used one like that for a Yaesu, And used 100 Ohm resistors in series to avoid smoke.
    The resistors may not be required, But I added them to protect my radio.
    Have Fun.
  3. VE3TMT
  4. K6CLS
    K6CLS Ham Member QRZ Page
    Does the manual say the rs232 requires a null modem?
    Have you tried straight through RX to RX, TX to TX?
  5. KA9JLM
    CTS should go to RTS
  6. VE3TMT
    I'll try that,
    Should the RXD and TXD lines be crossed or RXD to RXD, TXD to TXD?
    Max
  7. KA9JLM
    You have those correct, If you are sure of the port pins.
    Inputs go to outputs and outputs go to inputs.
    Good Luck.
  8. VE3TMT
    According to the datasheet:
    So...brown wire (CTS) to radio RTS pin, green wire (RTS) to radio CTS pin, orange wire (TXD) to radio RXD pin, yellow wire (RXD) to radio TXD pin. Ground to ground.
    Is that correct?
  9. KA9JLM
    Yes.
  10. VE3TMT
    Thank you, will give it a try tonight.
