HF antenna stealth dipoles for QRP, portable or home QTH
Discussion in 'Amateur Radio News' started by KJ4YZI, Dec 17, 2016.
  1. N8QZH
    N8QZH Ham Member QRZ Page
    Very good point, And many of us do just that. These are so simple anyone could do it. IF they want to, but some people i guess just dont want to mess with doing it.......
  2. KE0EYJ
    KE0EYJ Ham Member QRZ Page
    They sells some nice Chinese-made versions of these for a pretty good price, under the Windcamp name. They are sold on Aliexpress, and probably Ebay.
    I have not purchased one, but I have bought a few "B Delta 5IK" baluns from there, and had good luck.
  3. EI1706
    EI1706 QRZ Member
    Hi from Ireland, I can confirm simplicity works. I have simple dipole (runs NS) for 12m just under ridge tile at one end of loft (attic in US?) in bungalow aprox 15 ft up which got me (not much on 12 now) WWV on 15 Mhz and ZD7VC St Helina earlier in March this year. Rx is SDR (TV dongle into MacBook). Plenty more wires up there and 10KV local distribution in field next door so polar diagram is more a circle then anything else!
    I have same, but each end 10ft hangs down, for 20m at other end of loft. This gets me into east coast US and down to S Carolina (but you can use 10KW can't you!!!!!). I also heard very weak VE reply to an Italian CQ call so when conditions are OK, and the grey line is in the right place, things can be interesting.
    Currently the callsign is Irish SWL, I want to pass the CW exam to get a two letter callsign instead of a three letter one, oneupmanship I couldn't resist! I want to try CW as its more Km/Kw and some digital modes in due course.
    Best wishes for the new year. john m EI1706
  4. DU3LA
    DU3LA Ham Member QRZ Page
    BNC Female to Dual Banana Female Oscilloscope Test connector for center insulator, some 18 gauge wire, 2 insulators for each leg of the dipole. 234/operating freq for each leg (feet). You will have a portable dipole for you go kit! I have been making dipoles like this for years for portable and home use and they will handle 100 watts with no problems. The pic of the dipole looks like he is using a Oscilloscope test connector with some heat shrink over it?
    Just like N4NSS make your own antennas!
    By the way you can cut several wires to proper length for bands and then mark them, unscrew the banana jack's on the Oscilloscope test connector to change the freq. The whole package will be very small for portable or go kit's. If installed as inverted vee antenna the length of the wire will be shorter then a standard dipole!
    The price of DIY will save you a lot of money!
    You can also change the antenna type, 1/4 wave vertical, off center fed dipole, vertical dipole, loop antenna, plug 2 BNC Male and Female Oscilloscope Test connectors together and you can feed with open line.
