Help with TR-751A Vol/SQL control
Discussion in 'General Technical Questions and Answers' started by KE6YMA, Nov 7, 2017.
  1. KE6YMA
    KE6YMA Ham Member QRZ Page
    Hello, I have just bought a Kenwood TR-751A 2 meter and the Volume/Squelch knob in Volume cuts in/Out and the Squelch never breaks to static.
    I've pulled the potentiometer Out of the unit but looks like I'll distroy it attempting to repair it.
    Anybody know of a good solid repair or somewhere I can send it.
  2. W1VT
    W1VT Ham Member QRZ Page
  3. N5MOA
    N5MOA Subscriber QRZ Page
    The replacements from rrcom, I forget the p.n., work. You will need to tweak the legs a bit to fit on the board.
    And it will be twist on/off, not push like the original.
  4. KA9JLM
    I would try to stand it on end and apply alcohol to the control shaft, Rotate it so the alcohol gets to the carbon.
    I have done this and it can work, With nothing to lose, Unless you use Everclear. :oops:
    Good Luck.
  5. W9GB
    ALPS was the OEM supplier of this Dual-unit potentiometer.
    The original model is likely discontinued, but you can check current production models.
    http://www.alps.com/prod/info/E/HTM...otentiometers/RotaryPotentiometers_list1.html
    STATE Electronics, contact Thomas Sutcliffe for potential replacements / substitutions.
    http://potentiometers.com/
    Mod-Pot SERIES OPTIONS
    http://potentiometers.com/PDF/ModPotSelector.pdf
    STATE ELECTRONICS PARTS CORP
    36 STATE ROUTE 10 STE 6
    PO BOX 436
    EAST HANOVER NJ 07936-0436
    (800) 631-8083
    Local: (973) 887-2550
    Fax: (973) 887-1940
  6. KE6YMA
  7. KE6YMA
    Thanks Everyone,
    Great info
    Gary
    Ke6yma
  8. W9GB
  9. AA3EE
    AA3EE Ham Member QRZ Page
    One of the guys on a microwave related mailing list has detailed how he's been trying to salvage the original pot. I think the problem, once you disassemble it by drilling out the tiny rivets, is finding something to hold it back together.
    GL
    Dave AA3EE
  10. KA9JLM
    I would just replace it if has been removed.
    Yes that can be done, I have done it. But cleaning can be done without disassembly.
