ad: vanity
Help with Kenwood ts 480sat
Discussion in 'General Technical Questions and Answers' started by KB5RLM, Jun 1, 2019.
  1. AI3V
    AI3V Ham Member QRZ Page
    If you look up the transistor manufacturers data sheet for your final, and look for a graph with a title "imd vs power output" you'll see why running "flat out" is not a very good idea.
    You may also see something like "guaranteed to make xxx watts into any vswr at yyy volts without damage"
    If the manufacturer could get "more juice with less squeeze" :) they would.
    Rege
  2. KC8VWM
    KC8VWM Ham Member QRZ Page
    You need to use a peak reading meter to observe your true power output.
    Incidentally, your power output should be measured while TX'ing using CW. Whistling and yelling into the mic etc. on SSB isn't going to provide you with any kind of accurate reading.
    KU3X likes this.
  3. W5LZ
    W5LZ Ham Member QRZ Page
    "Whistling and yelling into the mic etc. on SSB isn't going to provide you with any kind of accurate reading."
    No but them big numbers are impressive, right??
  4. KF5PAL
    KF5PAL Ham Member QRZ Page
    Also when you test, be sure to bypass the onboard ATU, it will rob you of some output. I notice this on my 480 when driving my amp.
    KC8VWM likes this.
