Help Needed with EchoHam.
Discussion in 'Echolink/IRLP Tech Board' started by WB0MSZ, Sep 15, 2021.
  1. WB0MSZ
    WB0MSZ Ham Member QRZ Page
    I have a verified EchoLink account which I am able to use flawlessly on my iPhone. Yet, I am unable to get EchoHam (version 2.14) to work on my MacBook Air running High Sierra (macOS 10.13.6). It installs without a problem but will not connect to any station, even though I have read and tried all the suggestions I have found in the documentation. So after being a ham for over 50 years, I find myself in need of an "Elmer" who knows the secrets. What say?
  2. KA9JLM
    Many times it is a I/O Port issue. Did you setup port forwarding ?
    You can use a Public Proxy to connect if all else fails.
    Good Luck.
  3. WB0MSZ
    I want to try the public proxy approach first. Are you suggesting I choose a public proxy from the pull-down list under the Proxy tab in EcchoHam Preferences? Is there one in particular that you know should be up and running? All that I have tried EchoHam won't connect to.
  4. WB0MSZ
    I just wanted to let you know I got my ports configured properly and now EchoHam is working. Amazing! Thanks for your help.
    KA9JLM likes this.
