ad: vanity
Heil Parametric Receive Audio Set
Discussion in 'The QRZ 25th Anniversary Trivia Sweepstakes Prizes' started by AA7BQ, Sep 5, 2018.
  1. AA7BQ
    AA7BQ QRZ Founder Administrator QRZ Page
    Heil Sound, a proud sponsor of the QRZ 25th Anniversary Sweepstakes, has graciously donated a superb receive audio system including the outstanding Pro-7 headset AND the Heil Powered Speaker! This package will not only turn heads, your ears will love it too. Will you be the lucky winner?
    This fantastic Parametric Receive Audio System!
    Heil Sound and GigaParts have put together this fabulous audio combo. Included is the aviation quality Pro-7 headset, the Heil Parametric Receive Audio System (PRAS), and a really great Heil HPS-5 powered speaker. You'll have the best audio your shack has ever experienced!
    Click on any of the links below for more information about this outstanding audio set.
    https://www.gigaparts.com/heil-pro-set-7.html
    https://www.gigaparts.com/heil-sound-pras-parametric-receive-audio-system.html
    https://heilsound.com/amateur-radio-post/coming-soon-the-parametric-receive-audio-system/
    (From the Heil website)
    PRAS – Parametric Receive Audio System
    The Heil Parametric Receive Audio System (PRAS) is a state-of-the-art audio system that enhances the internal audio systems of amateur radio, shortwave, commercial, and CB receivers. The PRAS allows radio operators to modify, shape, and improve the audio output of their receivers using three separate equalization controls.
    Midrange frequencies are the most critical for achieving clear voice articulation in receive audio. The Parametric Receive Audio System allows operators to have unique control over these important frequencies. First, operators can adjust the parametric midrange filter from 400 Hz through 4 kHz, with the recommended sweet spot being at 2.5 kHz. In addition, operators can control the presence of these midrange frequencies plus or minus 15 dB. Combined with a low-frequency filter down to 160 Hz, and a high-frequency filter up to 6 kHz, the Parametric Receive System provides operators unparalleled control and quality of their receive audio.
    The PRAS has three audio inputs: standard XLR and 1/8” inputs, and an 8 ohm input that can be used with the 8 ohm speaker output of any receiver.
    There are three audio outputs on the PRAS: balanced XLR and 1/4” outputs on the rear panel, and a 1/8” output on the front panel for recording audio. The PRAS also has two built-in headphone amplifiers with separate level controls and dual 1/8” headphone outputs.
    The PRAS is intended to be used with the Heil HPS-5 powered speaker (the PRAS must be used with a powered speaker). The HPS-5 consists of a 24-watt, two-way, low-distortion amplifier using a titanium midrange tweeter and a 5” low-frequency speaker. The HPS-5, in combination with the PRAS, provides superb audio balance without distortion.
    The PRAS comes with an XLR-to-XLR cable to connect to the HPS-5, as well as a 12-volt DC power supply.
    HPS-5 – Heil Powered Speaker with 5” Driver
    The Heil Powered Speaker (HPS-5) is a two-way, powered speaker designed to be used with the Heil Parametric Receive Audio System (PRAS). The HPS-5 in combination with the PRAS provides unmatched speech articulation and brings new dimensions to receive audio quality. The end result is a fantastic listening experience that relieves ear fatigue for operators.
    The HPS-5 has a low-distortion, highly efficient Class D 24-watt amplifier that drives a specially designed 5” low-frequency speaker with a 3” magnet assembly mounted in a resonant sealed enclosure. A passive extended crossover drives a 2” high-frequency tweeter.
    The HPS-5 has two rear panel inputs: a balanced 600 ohm XLR input and an unbalanced 1/8” input. A single level control adjusts the input signals for both inputs. There is also a balanced 600 ohm XLR output for combining two or more HPS-5 powered speakers. Included with the HPS-5 is a 12 volt, 2 amp power supply, and a 2 amp fuse is mounted on the rear panel. Dimensions are 9” H x 7” W x 6” D.
    WB6MMJ, W2AI, KA2RRK and 3 others like this.
  2. N9NBC
    N9NBC Platinum Subscriber Platinum Subscriber QRZ Page
    nice one
  3. NK7Z
    NK7Z Premium Subscriber QRZ Page
    Where does one enter the Sweepstakes at?
  4. KA2CZU
    KA2CZU XML Subscriber QRZ Page
    I don't see the combo on the gigaparts site.
  5. KG4QAB
    KG4QAB Ham Member QRZ Page
    Great looking set up love to own one of those !!!
  6. KE8AQW
    KE8AQW Ham Member QRZ Page
    qrz.com/trivia
  7. NE1U
    NE1U Ham Member QRZ Page
    Well that made me feel like a complete idiot.
  8. PU2OLT
    PU2OLT Ham Member QRZ Page
    [QUOTE = "KE8AQW, postagem: 4803131, membro: 733805"] qrz.com/trivia [/ QUOTE]
    Friend, thank you so much, sorry, my love.
  9. N2RDQ
    N2RDQ Ham Member QRZ Page
    Id love to play with the parametric receive audio system, it looks pretty amazing.
  10. 9A6GEZ
    9A6GEZ Ham Member QRZ Page
    who would not like to have it and enjoy the quality of excellent sound ..
