Heathkit SB 610 filter cap replacement
Discussion in '"Boat Anchor" & Classic Equipment' started by KA2PVT, Jun 1, 2021.
  1. KA2PVT
    KA2PVT Ham Member QRZ Page
    I'm restoring an SB 610 monitor scope, and wondering if anyone has info on where a source for the .1uf 1200 volt , and .15 uf 1600 volt filter caps can be found. Thanks
  2. WA5VGO
    WA5VGO Ham Member QRZ Page
    Mouser.
  3. KA2PVT
    Looking for a couple of pieces only. Seems like Mouser, MCM only sell in large quantities. any other sites?
  4. W9GB
    Internet web sites and Refresh/Rebuild articles for Heathkit SB-610 have existed since the late 1960s.
    You should have a Paper Assembly Manual & Schematic to Reference on your Workbench.
    https://people.ohio.edu/postr/bapix/SB610.htm
    COVID-19 has disrupted production and supplies for SOME electronic components.
    National News tells you about ICs and processors used in automotive systems.
    IF you are looking for a “One-Stop” Kit of Parts (Capacitor Re-Cap kits) :
    Hayseed Hamfest (option for metal Can capacitor) - Cedar Rapids, Iowa
    https://hayseedhamfest.com/collections/heathkit/products/sb-610-re-cap-kit
    Data Professionals - Pleasanton, California
    http://www.d8apro.com/NewKits.html
    Kit Instructions
    http://www.d8apro.com/SBA-6XX-1.pdf
    Digi-Key Electronics (Thief River Falls, MN) - No minimum order,
    IN STOCK, expect $7 to $12 shipping charges (depending on carrier)
    CDE 942-series : 942C16P1K-F, 0.1 uFd, 1600 vdc Axial Lead
    https://www.digikey.com/en/products/detail/cornell-dubilier-electronics-cde/942C16P1K-F/1929475
    $4.58 each , In Stock You need at least two (2) for the SB-610 monitor
    Many order three (3) and sub the 0.1 uF value for the 0.15 uF value (see manual).
    CDE 940-series : 940C16P1K-F, 0.15 uFd, 1600 vdc Axial Lead
    https://www.digikey.com/en/products/detail/cornell-dubilier-electronics-cde/940C16P1K-F/809458
    $4.38 each , In StockYou need one (1) for the SB-610, unless you use three (3) of 0.1 uFd.
    Just Radios (David Cantelon) in Scarborough, ON / Niagara Falls, NY
    ($25 minimum orders)
    https://www.justradios.com/cart.html
    Refurbishing the Heathkit SB-610 and “The 610C-2 Makeover”
    by Stu Martin, K2QDE
    Revision: May 2007, Stu covers the 1969 K6SDE modifications
    http://collinsra.org/home/wp-content/uploads/2014/06/Heathkit-sb610.pdf
    Heathkit SB-610 Monitor Scope Modifications
    by Ian Webb, K6SDE
    73 Magazine, April 1969
    https://www.nostalgickitscentral.com/heath/73-index/articles/SB-610-4-69.pdf
    W6BRY likes this.
  5. KA2PVT
    Thanks so much for the information. Should have it going soon!
  6. WA5VGO
    This is incorrect. Mouser will sell in any quantity.
    AD5HR likes this.
  7. K8CCA
    K8CCA Ham Member QRZ Page
    I got the caps for my SB-610 from www.justradios.com in Canada. They do have a US$25 min however, but I usually don't have an issue making an order for that much.
    FWI pay attention to the large resistors tolerances. Mine had drifted significantly and really benefited from replacement. Seems like I remember that the focus circuit is a typical problem. I upped the wattage on mine and it's worked fine for a few years now.
  8. W3SLK
    W3SLK Ham Member QRZ Page
    Its strange. All the voltages on mine are within a few volts of what they are supposed to be, (some exceeding). Yet my display is very dim. I have the HV caps to replace but it looks like the voltages are within specifications. I specifically look in the FOCUS and Brightness circuits.
  9. KJ4YEV
    KJ4YEV Premium Subscriber QRZ Page
    Sounds like a weak CRT.
  10. WB9TEN
    WB9TEN Ham Member QRZ Page
    I've used the kits from both Data Pro and Hayseed Hamfest. Both are well worth the money.
