Heathkit 644 remote vfo plug
Discussion in '"Boat Anchor" & Classic Equipment' started by VE7GPG, Dec 5, 2018.
ad: DLSpec-1
  1. VE7GPG
    VE7GPG XML Subscriber QRZ Page
    I'm building a cable for the remote VFO - I can get the Octal plug from EBAY - but can't seem to find the one for the white plug on the VFO - has anyone a lead on a source for it?
    Thanks
  2. N8YX
    N8YX Ham Member QRZ Page
    That's a Molex connector. Digikey and Mouser have them, and you can probably source from eBay as well.
  3. VE7GPG
    Thanks, I couldn't find one in my simple searching there, I'll dig deeper !
  4. K7TRF
  5. VE7GPG
    that's it ! thanks !!!
  6. W9GB
    Most common Molex nylon connectors from 1970s to 1990s were their
    0.062” and 0.093” pin/socket connectors.
    After the Koch Industries acquisition of Molex, some higher pin count (>15-pin) connectors were discontinued. One casualty, Molex (0.062”) 24-pin accessory connector used by Icom.
    Waldom of Rockford, IL (Molex Distributor)
    https://www.waldom.com/Suppliers/Molex.html?m=25
    Multiple Circuit Connector Kits (Molex)
    • Kits include matching male and female polarized, nylon connectors
    • Comes complete with corresponding pins
    • UL recognized, CSA approved
    • Maximum voltage: 250 volts
    • For 18 to 22 gauge wire, 0.093" diameter pins.
    Part Number 76650-0055
    0.093” 9-circuit connector with receptacle & plug
    8B2247F5-92B3-4C68-9A1D-7516C394F3C3.jpeg A8C44F83-ED35-4955-8DFF-025D442FE497.jpeg 391F4CF7-321D-4CF9-9111-B5BF6730A968.jpeg
    Contents of the Retail Packaged Kit
    Qty. 11 : 02-09-1119 - .093" (2.36mm) Diameter Crimp Female Socket Terminal, 22-18 AWG
    Qty. 11 : 02-09-2118 - .093" (2.36mm) Diameter Crimp Male Pin Terminal, 22-18 AWG
    Qty 1 : 03-09-1091 - 9 Circuit, Panel Mount Nylon Connector Receptacle
    Qty 1 : 03-09-2091 - 9 Circuit, Panel Mount Nylon Connector Plug
    DATASHEET
    https://www.parts-express.com/pedocs/specs/Molex 9 way 092-562s.pdf
    SHOP FOR BEST PRICE : One Internet reseller (San Antonio, TX) selling for $3.92
    http://www.intertexelectronics.com/...ex-Plug-Receptacle-Contacts-9-CKT-P10920.aspx
  7. VE7GPG
    Turns out - it's a 6 pin - but they have those also !
    Thanks !
  8. W9GB
  9. VE7GPG
    Thanks again !
    You are a fountain of great info, really appreciate the source of CRT tubes for SB-614 should that turn out to be the problem
