Heath DX-40: two different modulator circuits?
Discussion in '"Boat Anchor" & Classic Equipment' started by K5DH, Aug 11, 2018.
  1. K5DH
    K5DH Ham Member QRZ Page
    Okay, DX-40 mavens, let's see if you can help me. I've seen photos of the underside of various DX-40 chassis and it looks like there were two different circuits, mainly in the modulator section. I'm fixing up a DX-40 whose modulator section differs quite a bit from the schematic that I have, but the circuitry looks just like a bunch of the photos I've seen on line. I recall seeing a reference to there being two different circuits, but I can't find it. Can someone shed some light here? If there are two different circuits, which one is better and why?
  2. N2EY
    I'm no DX-40 maven, nor an expert in anything.....but I'd like to help if I can.
    Can you show us some photos and trace out the as-wired circuits?
    The DX-40 uses a form of controlled-carrier screen modulation. The basic circuit operation is explained in the manual. It's possible that some folks didn't like the controlled-carrier system and changed it to straight screen modulation, despite the fact that controlled carrier gives more power output.
    73 de Jim, N2EY
  3. K9STH
    There was a change made by Heath with the modulator in the DX-40 sometime in the production run. However, I have no documentation as to just what was changed and exactly when the change was made.
    There has been some information on this posted on one of the boat anchor E-Mail reflectors quite a ways back. But, I just do not know on which reflector the information appeared.
    The only thing that I remember was that certain component values were changed to increase the audio power and to improve the frequency response.
  4. AC0OB
    AC0OB Subscriber QRZ Page
    These are the latest upgrades I use for a DX-40:
    Pheel
  5. HAMHOCK75
    HAMHOCK75 QRZ Member
    Not sure if this helps but I do restorations and have restored a DX60B and a DX35 but not the DX40. If some earlier versions of the DX40 used a modulator similar to the DX35 then it will have a problem achieving AM modulation of 90%. My notes show that I discovered both the DX40 and DX60 achieve high modulation % with a high pass network at the output of the cathode follower that drives the screen grid of the 6146 final.
    I tested that on the DX35 and it was able to achieve the same modulation depth as the DX60B. I then returned the DX35 to its original state.
