Hanging ends on a G5RV
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by WA3ERQ, Nov 17, 2009.
  1. WA3ERQ
    WA3ERQ XML Subscriber QRZ Page
    What would be the maximum amount of each leg of a G5RV that can "hang" due to limited space?
    I currently have my G5RV as an inverted "v" but depending on how much of each end I can allow to hang, I may be able to get a more straight line.
    Thanks and '73
    Jim
    WA3ERQ
  2. N3XP
    N3XP Ham Member QRZ Page
    On a 206ft G5RV I had one leg hanging vertical for about 25 feet and the other about 12 feet. I worked all kinds of stuff in that config.
  3. AE5TE
    AE5TE Ham Member QRZ Page
    If you are at a relatively obtuse angle (say 120 dgrees or better) in your inverted vee configuration you're probably alright just as it is.
    If I were contemplating using the same space for a flat top with hanging ends I think I'd spend the effort on a regular 80M dipole.
  4. WA3ERQ
    Just curious. When people string their wire dipoles in trees, is there a safety risk or decrease in efficiency if the ends touch any branches?
    Tnx
    Jim
    WA3ERQ
  5. AE5TE
    I don't get too excited about dry wood but in rain & snow you can figure tuning will be affected. Tree rats will play with the wires too - I don't know or care much how RF training affects them.
  6. G0GQK
    G0GQK Ham Member QRZ Page
    As suggested by the man upstairs with the two fingers I agree with what he writes. An 80 metre dipole is approximately 135 feet long and you can drop about a third of each leg vertically. This is much much easier to tune on all the bands than one of those G5RV's but people take a lot of persuading. Use open wire feeder, any length to fit the space, connect to a 4:1 balun then coax into the shack to the ATU, then coax to the SWR/POWER meter, and then a short piece of coax to the tranceiver. And that is the best all band dipole.
    G0GQK
