Hammarlund hq 145 help
Discussion in '"Boat Anchor" & Classic Equipment' started by RAYSUNCLOUDS, Nov 8, 2019.
  1. RAYSUNCLOUDS
    RAYSUNCLOUDS QRZ Member
    I've had this radio 1 year,listen on 80m and 40m.Was a ham wd8cyx in 1970's.The hf band 10-30 MHz is dead. Any thoughts on how to start checking it out? Thinking about buying a tube set for starters.
  2. K9STH
    Try replacing V-9 the tunable oscillator tube. This is a 6C4. This tube is well known for causing problems in the Hammarlund receivers. Unfortunately, a lot of 6C4 tubes are problematic even when brand new.
    N2EY likes this.
  3. RAYSUNCLOUDS
    Thanks,Glen. I bought this hamm hq 145 about 1 yr. ago, and usually listen on 80&40m ,I keep hearing about 20m improving, but on the 10-30m band no background noise, just some popping here and there. 1.6m-10meter are strong.When I had my liscence 1970s,I built a hw101 and liked it, but this Hammarlund is pure luxury compared to the heath. Also now I have room for a good antenna, I strung an 80 meter half square and it is just amazing. I the city with the hw101 I just strung wire in my attic. Poor sig, the only people who called me back were a couple of Christian nets. Anyway I will follow up on any suggestions I hear.73,Ray.
  4. KK6IYM
    KK6IYM Ham Member QRZ Page
    You should read the manual. This radio uses dual conversion on the bands above 10 MHz, so it sounds like your problem is there. The radio has a crystal used for the second conversion and it may be the problem or the bandswitch may be giving you trouble. In general, crystals can fail, but rarely do.
    Norm
  5. K9STH
    If you don't have the manual, I have an excellent PDF of this. E-Mail me at
    k9sth (at) sbcglobal (dot) net
    and I can forward the manual to you.
    KE4OH and N2EY like this.
