ad: portazero-1
Ham Radio - An end fed half wave cage antenna. How much wider bandwidth does it provide?
Discussion in 'Amateur Radio News' started by KB7TBT, Apr 25, 2021.
  1. KB7TBT
    KB7TBT Ham Member QRZ Page
    WJ2L, K1CWB, TA2EE and 7 others like this.
  2. W8AAZ
    W8AAZ Ham Member QRZ Page
    Has he done it with a pair of wires spread apart at one end and terminated together at the feed end? That would be a simpler way to get a wider element for homebrew antennas. I would think that could add bandwidth without so much wire and weight. The hams in the old days has issues with antennas like that from weight, ice buildup, wind load, etc. that you would expect over a single wire.
    JF1IRQ, K7IWW and HB9EPC like this.
  3. HB9EPC
    HB9EPC Ham Member QRZ Page
    Comme la bien expliqué W8AAZ, le poids de la neige en montagne est énorme.
    UNE+Chris
    IW3ILM likes this.
  4. W1YW
    Oh Jeez,
    Should I build my Marconi shack also?
    There are plenty of ways of getting acceptable bandwidth; the cage antenna is seldom used by hams because it is a large and cumbersome option.
    K2XT likes this.
  5. KI5DJ
    KI5DJ Ham Member QRZ Page
    Well, hey a good assessment.
  6. KA4DPO
    I have built a few three wire dipoles for ten meters, the wire size and spacing can pretty easily be adjusted to work with 600 ohm open wire line. The additional bandwidth is a bonus, a three wire dipole with about two foot spacing will easily cover 2 MHZ of bandwidth at 2:1 SWR on ten. The thing with cage antennas is that to realize a lot of band width at frequencies below 14 MHZ, the physical dimensions become a problem.
    WN1MB likes this.
  7. KC8IKW
    KC8IKW Premium Subscriber QRZ Page
    Hello from kc8ikw Joseph Strauss I love how u made that If u can who made the rings can u send me that information thank u very much from kc8ikw Joseph Strauss as all way every one calls me Joey 73s
  8. KK9W
    KK9W Ham Member QRZ Page
    He went through the experiment to see what would happen and that's all he set out to do. He even said it didn't have any advantages due to being impractical but the antenna did in fact offer wider bandwidth. He took the time to satisfy his curiousity and cared enough to share the experience and the lesson. I learned something and others likely did too. Not sure why the sour attitude.
    K1CWB, W4WYD, WA8MEA and 11 others like this.
  9. W1YW
    Not sour, just realistic. It is not unlike using spark instead of any modern mode.
    Cage antennas still see occasional use in high powered applications, but not in ham radio in anything but an anecdotal way.
    The most famous use of cage antennas is the DUGA array--very QRO.. Take a look at it on google, for example.
    Chip W1YW
    NL7W likes this.
  10. KK9W
    I agree it isn't realistic but it wasn't what he was aiming for. Only to answer a single question of bandwidth result of the design.
    K4FMH, N7DWX, KK4NA and 1 other person like this.
  11. W1YW
    I could argue: to what end?
    It is much more enlightening for us to see where cage dipoles are used, and when they are used.
    Again: fun to look at the Duga for some fairly recent history. I will post one by my daughter in law's brother later. He was there! (I am jealous).
    Chip W1YW
  12. W8AAZ
    OK so impractical in most situations but interesting. I wonder if the old spark hams had any idea about the broader bandwidth. I know they had wide spaced flat tops with lots of wire, and they were considering that those has more "capacitance" than a single wire, for loading purposes, presumably. Gigantic capacity hats to make the feeder efficient as a radiator at lower freqs? Then again, their understanding of antennas was pretty rudimentary for a long time. Explaining some of the monstrosities seen in old literature. Adjust for maximum RF current on the feedline.
  13. W1YW
    Here is a 2020 photo of the (defunct) DUGA (Woodpecker) array. The antenna was an array of caged dipoles with tapered-to-feed construction. 3:1 bandwidth from 7-21 Megs approximately.
  14. PA0MHS
    PA0MHS Ham Member QRZ Page
    C'mon Chip, you of all people should understand the urge to experiment.
    KK9W likes this.
  15. W1YW
    C'mon what...
    Here's a good experiment you can do with a cage antenna--
    Run a parasitic wire (no connection) down the middle with distributed capacitors on its length (A CCD antenna) .
    This will have an interesting effect on the bandwidth and beam pattern (at some frequencies) with the right choice of capacitors...which...as is the point.. one can experiment.
    W0PV likes this.
