ad: SalmonRn-1
Grounding Do's Don'ts & Why Part 3
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KF5LJW, Mar 19, 2012.
  1. N5YPJ
    N5YPJ QRZ Moderator QRZ Page
    Thanks .
  2. KF5CCN
    KF5CCN Ham Member QRZ Page
    I feel your pain. Either go to a balanced antenna, dipole or loop or move your shack to the garage (not really a bad thing) end-fed antennas are not so good IMHO.
    KF5KWO likes this.
  3. NUMBERFIVE
    NUMBERFIVE QRZ Member
    hello gents.
    I have question / issue that is very relevant to the grounding of my PC, but not relevant to ham family at all.
    My 144hz monitor is looking like the refresh rate is below 60hz, both on the desktop and while gaming. And the mouse movements are inconsistent.
    We have a discord group of people with the same issue, we did a lot of testing with involvement of professional equipment and electricians.
    The root cause seems to be in the grounding, and we have a success story of a guy who installed a proper 9ft copper rod under his yard and the issue went away.
    But the problem is that those of us who live in the apartments, usually cannot mess with the grid beyond the the counter.
    We are going into the area of "self contained power and signal reference system" used in the aircraft now.
    But since this is something that is plaguing the hams as well, I was hoping for an advanced advise here - is there any way to have a signal reference system built somehow at home, if proper grounding is not available?
    Open for any suggestions
  4. WR2E
    WR2E Ham Member QRZ Page
    I'm not buying it.
    N0TZU likes this.
  5. W9JEF
    W9JEF Platinum Subscriber Platinum Subscriber QRZ Page
    Hope this helps:
    https://en.wikipedia.org/wiki/Counterpoise_(ground_system)
  6. N0TZU
    Me either. No way grounding would cause those.
    The only possible way an erratic mouse might be related to grounding is if static electricity were charging the mouse, but they are grounded through the computer three wire plug. If a wireless mouse, grounding wouldn’t help at all. A static reducing surface or spraying Static Guard or similar on the mousing surface would help.
    But I’ve never heard of a mouse static problem. Almost certainly the erratic problem is lint or dust in the optical path of the mouse.
  7. WR2E
    Maybe you could try one of these?
    https://www.entreq.com/products/ground-boxes-17667704
    Make sure to use the "Eartha Cables" that go with them.
    https://www.entreq.com/products/eartha-cables-17667932
    Maybe you could make one of your own? Get a plywood box, coil up some copper wire inside and fill it with dirt. You could probably even plant some herbs in it.
    W6KCS and N0TZU like this.
  8. KD2ACO
    W9JEF and WR2E like this.
  9. N0TZU
    Fresh or “broken in” cat litter?
  10. WR2E
    SA6CKE likes this.
ad: AlphaRF-1
