GridTracker - A WSJT-X Companion
Discussion in 'Amateur Radio Software' started by N0TTL, Feb 7, 2018.
  1. K8RFT
    K8RFT Ham Member QRZ Page
    It has been almost two years since I posted the above, and tried out the current version (1.20.0302). It installed without problem, but still gives the same error and will not run. Is there any known cure? I've made over 1,000 FT8 contacts now, and use JTAlert all the time - but I would _Really_ like to be able to see the map!
    Thanks,
    Doug, K8RFT
  2. N2IPH
    N2IPH Premium Subscriber QRZ Page
    Well part of your problem might be you are running such an old version of Windows.
    I'm sure you are aware of that so I won't elaborate on it. My suggestion would bo to try the copy of GT you downloaded on another computer with a more up to date OS. If it works then you can assume the problem lies with your OS which was replaced in 2009 and support ended in 2017.
  3. WA6MHZ
    This is GREAT!!! I couldn't get JT ALERT to work, it always comes up with UDP errors, but this works fine!!
  4. K8RFT
    Or it might not. However, I'm not in a position to spend a couple thousand dollars and a month or so of getting a whole new system set up and then find out that it made no difference.
    I couldn't find any mention of Gridtracker having OS limitations, and still can't.
  5. K4PGD
    K4PGD Ham Member QRZ Page
    Hi All -
    Appreciate if anyone can help as I couldn't find a solutions...
    When I complete a QSO and GridTracker uploads to LOTW I get the following error pop up - error: qso date is not within the date range specified on your callsign certificate
    I notice if I manually upload a file it prompts to enter a date or leave it blank...
    Did I leave out something or mis-configure a cert?
    Thanks for any help in advance -
    Greg
  6. ND6M
    ND6M Ham Member QRZ Page
    On the reporting tab, do you have all 3 boxes checked?
  7. K4PGD
    Got it - I had to renew with 'no' end date. I had inadvertently entered a date and it expired.
  8. W0AQ
    W0AQ XML Subscriber QRZ Page
    GridTracker is updated! (Phone sofa).
  9. N0JYZ
    N0JYZ Ham Member QRZ Page
    I'm sitting here on my phone-sofa and am confused. I wonder why "ALL" was removed from "band" selection on the "Map View Filters" section in the most recent updates. It bugs me because I used it to get a better visual of various awards aggregated on ALL bands, rather than just one band.
  10. N0TTL
    N0TTL Premium Subscriber QRZ Page
    ALL wasn't removed.. it was renamed to "Mixed" as that's the proper name for it.
    K5EMG likes this.
