Good multi-band wire antenna < 75' long
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KD0KZE, Apr 7, 2021.
  1. KD0KZE
    KD0KZE Ham Member QRZ Page
    The crux of my problem is that I really only have about 75' to work with, since there are branches that extend outward from the thicker branches I loop the paracord around. I'd like the antenna to hang free and clear of all branches. In the past, I didn't mind if I had to pass the G5RV through small branches, but I think it would be begging for trouble with a fan dipole like an Alpha Delta product, and I note that there are coils on both ends, near the end insulators, making it all the more desirable to be further from trees.
    I now have a loop of paracord suspended near the center point, and have found with my experimental hanging location that a center support makes a huge difference. I wish I could make an inverted-v, since this would use up some of the overall length (in a deliberate way), but I can't get the center high enough for that. Trees are sure cheaper than towers, but they're not laid out the way you really want them.
    73, KD0KZE / Paul
    What supports the paracord at the center?
    Trees may be cheaper than towers, but "masts" aren't expensive at all and can easily go to 45' or so.
