Getting 80m and 30m bands from my 43' vertical?
Discussion in 'General Technical Questions and Answers' started by KI1SPK, Nov 6, 2018.
  1. WA7ARK
    WA7ARK Ham Member QRZ Page
    Using EzNec and AutoEZ, here is a sim of a 43ft 2in dia aluminum pipe standing on 8 30ft radials. (Let me know if yours is a lot different than this).
    First, here is the predicted feed-point impedance R and X at selected frequencies:
    On 60m, the pole is almost 1/4 wavelength (nearly resonant), so would almost match by switching out the tuner.
    I then asked AutoEz to compute a low-pass L-network to be inserted at the pole base to convert the R and jX above to 50+j0 at each of the frequencies. The K column is the required shunt capacitor in pF; the L column is the required series inductance in uH. The M column tells us if the configuration of the L-network; capacitor at input or capacitor across the feedpoint.
    Notice that on 80m and 60m, the required capacitance is large, likely more than your auto-tuner can supply.
    You could fix this by using a relay to switch in an additional fixed capacitor across the tuner input only on 80m and 60m.
ad: UR5CDX-1
