FT 897 won't power on.
Discussion in 'Radio Circuits, Repair & Performance' started by KD4BOH, Jan 16, 2020.
  1. KD4BOH
    KD4BOH Ham Member QRZ Page
    My 897 won't power on. I know there is a kit you can buy to repair it. Where can I get info on repairing it in English and get the kit ? Bruce.
  2. WD8BWW
    WD8BWW XML Subscriber QRZ Page
    There are several things that will prevent an 897 from powering up. The kit you are talking about is a collection of the typical parts that go bad. I have seen these on Ebay from time to time. I have repaired several of these. Using a low current power supply, voltmeter and the service manual, check to see if the un-switched 13v is present at the ribbon cable on the Main board. If it is not, trace the diodes and transistors on the PA board ( bottom side) that supply the un-switched 13 volts to the main board. If it is present, then check the "power on circuit" to see if it is switching with the power switch. If it is working trace back to the power on relay drive transistor. Let me know what you find.
    KJ4VTH likes this.
  3. K1LKP
    K1LKP Premium Subscriber QRZ Page
    Hi BRUCE,
    CAN YOU GIVE US SOME INFO REGARDING THIS UNIT.....
    WAS IS WORKING JUST FINE AND ALL OF A SUDDEN IT DIED.
    WERE YOU DOING ANYTHING DIFFERENT TO THE UNIT
    WHEN IT STOPPED WORKING.
    JUST NEED SOME PRELIMINARY INFO TO HELP YOU RESOLVE THIS
    PROBLEM.
    SOUNDS LIKE WD8BWW IS VERY FAMILIAR WITH THIS UNIT AND
    WILL HELP TO GET YOUR PROBLEM RESOLVED.
    HANG IN THERE AND KEEP SMILING.
    73 - K1LKP
