FT-891 & Flrig
Discussion in 'Ham Radio Discussions' started by G0WSJ, Jan 22, 2021.
ad: QSOToday-1
  1. G0WSJ
    G0WSJ XML Subscriber QRZ Page
    Never been big on CAT control, but thought I would have a play with Flrig and see if I'm going to use it before spending money on a decent piece of logging & CAT software.
    Now, I've had the 891 for a few months and have had a great deal of success on FT8 using JTDX and the SCU-17. But for the life of me I just cannot get Flrig to work. The closest I have got is for the radio to go into TX, and I've had to switch it off to stop it.
    I must be missing something fairly obvious, but if radio & SCU-17 are working with JTDX (changing bands, keying up) what am I doing wrong with Flrig?
    Any help greatly appreciated.
  2. KC3PBI
    KC3PBI XML Subscriber QRZ Page
    These settings worked for me the last time I set up a similar Yaesu for fldigi:
    (flrig transceiver settings pane should appear identical to this)
    If there isn't something helpful in that image, maybe post a picture of your (working) JTDX settings and we can try to translate?
  3. G0WSJ
    These are my settings for the radio & SCU17 within JTDX
    I guess CAT control should be on port 6. Do I need the SCU in place as well ? I don't want the radio to PTT, it's just CAT control I'm after. (and logging at a later date)
  4. KC3PBI
    okay you've got dual port control going there in JTDX and flrig thinks it's single.
    An attempt at translating:
    fldigi xcvr pane:
    rig ft891
    port com6
    baud 4800
    select 2 stop bits, deselect rts/cts
    switch to ptt pane:
    uncheck everything in cw mode and cat port ptt options
    in the bottom ptt control on separate serial port: select com4 and check ptt via rts
    Hope that helps, good luck!
  5. G0WSJ
    I'm confused why I should be using Fldigi, when I only want to use CAT?
  6. KC3PBI
    typo/caffeine deficiency. I typed fldigi when I should've done flrig; apologies.
  7. G0WSJ
    :D I know that feeling. That will be tomorrows project, the FT8 is good on 30M this evening in SW England :)
