ft-8900 no 2m TX
Discussion in 'Radio Circuits, Repair & Performance' started by N1EBC, Oct 10, 2021.
  1. N1EBC
    N1EBC Ham Member QRZ Page
    I have a FT-8900 radio everything works fine except the 2m tx.
    anyone willing to walk with me or walk me through the repair?
    attached service manual and manual.
    This evening I will be setting everything up for working on it. I have scope, dummy load, and can probably come up with whatever else might be needed.
    Thanks
    Jason
    N1EBC
  2. N1VAU
    N1VAU XML Subscriber QRZ Page
    First thing, MASTER RESET, then test to see if it works again.
  3. N1EBC
    Just did that. No change. Still no tx on 2m other bands ok
    Thanks
    Jason
    N1EBC
  4. W1NB
    W1NB XML Subscriber QRZ Page
    Jason,
    I would start by checking the VHF oscillator Q1111 output. Depending on what you find you can go forward or backward from there.
    Scott, W1NB
  5. K7JEM
    K7JEM Ham Member QRZ Page
    If you listen on a nearby handheld radio, tuned to 146.52, or some simplex frequency, can you hear yourself transmitting? Trying to determine if your radio is working up to the final amplifier, or making sure that the lower level stages are working.
  6. N1EBC
    Yes it works both ways TX/RX
    Jason
    N1EBC
  7. N1EBC
    Just wanted to be sure that this also answers what you ask
    Thanks
    Jason
    N1EBC
  8. W1NB
    Not necessarily. The buffer stage, pre driver stage, driver stage or final stage could be bad but still generate enough RF to be heard on a receiver. I suggested starting at the buffer because it’s the first stage after the oscillator and is likely on a different voltage rail from the PA section.
    Do you have a solder/desolder station to replace SMD devices?
  9. N1EBC
    Ok Fair enough.. Haven't had time to lay stuff out. I'll get everything setup for probing. I have a scope, solder iron, desolder gun , and a hot air gun(which I am super hesitant to use).
    After work tomorrow I'll probe the oscillator . On this radio we know the final works as 70cm, 10m, 6m all put out wattage on the watt meter. So i guess while I'm probing I will also check the input of the final then the output. And get back to you. Reason why not tonight is I try not to do too much technical this late as more mistakes happen when I'm tired. But I'll have everything ready for after work tomorrow.
    Thanks,
    Jason
    N1EBC
  10. N1EBC
    Ok I got it setup and couldn't wait. So I have a signal at q1111 and I also have a large signal on the output of the final.
    So I'm ready to move forward after work tomorrow.
    Thanks for your time.
    nosaj
    N1EBC
    On the image red arrows are where I got signal at.
