Fidigi not showing text
Discussion in 'Rig Control, Prop., Cluster, & Other Software' started by K1NFD, Sep 22, 2018.
Tags:
ad: QSOToday-1
  1. K1NFD
    K1NFD Ham Member QRZ Page
    I have been using Fidigi for about a month Have version 4.0.18 It decodes properly on the left panel but stopped showing any text on the upper right panel (received text). clicking on either the text stream on the left or the signal on the waterfall will not make it work. Once in a while a single character appears. I updated the program exited and re-started multiple times. No effect. Any ideas?
  2. KD3WB
    KD3WB Ham Member QRZ Page
    Make sure the squelch is set correctly. Gray, vertical rectangle with a white dot to the right of the waterfall.
    Ben
  3. K1NFD
    That was it. After making this post (and that after trying most everything else) I saw that the slider on the very right of the waterfall has been put to the top. I had no idea there was a squelch. Some time I will see if there is a list of what all the gadgets on the screen do.
