ad: Flexradio-1
feeding 2 40m delta loops with ...one coax !!one loop east one loop west
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by VE3ZSZ, Aug 14, 2021.
  1. VE3ZSZ
    VE3ZSZ Ham Member QRZ Page
    i am putting up 2 40m loops and i have seen one coax in center
    can anyone help please
    sam ve3zsz
  2. 2E0VSS
    2E0VSS Ham Member QRZ Page
    Both are the same?
    They have the same directionality .
    If you had said “one East west and one North south and fed them with two separate coax feeds so they would be switchable your post would make sense.
    As it stands now you post makes non-sense.. If you see what I mean..
    M
    RW4HFN likes this.
  3. VE3ZSZ
    lol
    my post is nonsense lol
    because feeding two delta loops with one coax has been done before !!!
    im asking where to feed ?
    are you saying it does not work what about connecting two deltas from one mast ..
    center ? earth one side fire in wire other
    you made me laugh because i won a bet thanks to you
    i bet 50 dollers that someone would say its nonsense beer and steak tonight
    thank you sir
  4. WA7ARK
    WA7ARK Ham Member QRZ Page
    Your question is not nonsense, and you should give back the $50...
    Is this the configuration you had in mind?
    Two horizontal three-sided (delta) loops, mirrored about the Y-axis, with a common feedpoint where the loops come together. Each loop is resonant on 40m (each side is ~47ft long).
    There are various ways to combine the loops depending on where you want to send your signal. The in-phase connection shown above has a feedpoint Z of 100 Ohms, but it sends max radiation straight up, so not very useful. It is worse than either loop would be by itself.
    If I connect the two loops out-of-phase, I get a feed Z of ~50 Ohms, and a figure 8 azimuth pattern with big gain along the -X and X axes, and deep nulls along the -Y and Y axes.
    This is with the two loops at 35ft agl.
    K0UO and VE3ZSZ like this.
  5. RW4HFN
    RW4HFN Ham Member QRZ Page
  6. VE3ZSZ
    this is so cool this info sir
    my 2 loops are slopeing
    one loop east
    one loop west
    40 feet at top of mast to 10 to 18 feet of ground bottom of loop
    but i think should work out ..
    so out of phase is what i am looking for dx is my thing
    if im right in this it means feed each delta loop
    with braid to one loop and copper to other i take it
    i have a 4.1 balun so i could use tuner and use it on other bands
    going to tune it for 7.185 both loops my main dx goal
    and use tuner for other bands
    Thank you sir you made my day
    i knew it was possible
    ..very much big 73
  7. VE3ZSZ
  8. VE7BPB
    VE7BPB Ham Member QRZ Page
    It occurs to me that if you only had two supports that the delta loops could be hung in a vertical orientation.
    With a small relay box at the feed point, one could switch to an in-phase broadside pattern, or an out-of-phase bi-directional pattern. At least that is what it looks like.
    Michael, could you show us a pattern based on that concept? It seems to me to be an easy way to get some beam steering without any phasing harnesses.
    regards, Roy
  9. 2E0VSS
    He didn't give any idea he was suspending them parallel to the ground.
    Are we supposed to read the Ops mind?
    Let's face it, had he said sky loop then it's a different story..
    Be honest, the first thing that comes to mind re the delta is in the vertical plane.
    I'm not David Blaine and was fully justified in saying that without more info it was. non-sensical
    I rest my case your honour..
    Over and out
    Beam me up Scotty
    Get me outa here
    Wink wink!!
    M
  10. VE3ZSZ
    no worries mate god bless
