fake callsign ce0x/**
Discussion in 'Community Help Center' started by CE6UFF, Feb 25, 2020.
ad: OK1UUad-1
  1. F0DUW
    F0DUW XML Subscriber QRZ Page
  2. F0DUW
  3. F0DUW
  4. CE6UFF
    CE6UFF Ham Member QRZ Page
    Fake radio not ham hobbie fake antena illegal call no antenna no coax no RF ...more ?.
    This is Joke hamsphere is not real ham radio .
  5. CE6UFF
    Oscar Villa <villambato@gmail.com>
    18:42 (hace 2 horas)
    para miltonmoutinho2007
    Hola amigo.
    Por favor ud puede informar o mostrar el documento que esta autorizado ese indicativo.
    Consultado hoy a SUBTEL, Subsecretaria de Telecomunicaciones. No estas Autorizado.
    es FALSO.
    Atte
    CE5CSV Oscar
    Discolodxgroup
    QRP.CHILEgroup
    Milton Moutinho
    20:18 (hace 1 hora)
    para mí
    Caro Señor Oscar.
    La operacion non eres real y si Estacion Remota de Hamsphere. Asi non tengo ainda la permiso de las autoridades de Chile. Non soy FALSO. Solamente estoy solicitando permision para trabajar CE0X en operacion de Estacion Remota.
    Señor Oscar non soy FALSO. Solamente estoy solicitando la permiso de Kelly junto a HAMSPHERE.
    Yo aguardo solamente la permiso para trabajar virtualmente la isla de San Felix.
    Atte
    Daniel, PT7BI.
    Therfore is invalid call not CE callsign is stupid that Kelly asign CE callsign ...go ahead with your toy
    Chilean laws and IARU heard about this crime .
  6. CE6UFF
  7. CE6UFF
    Radio Club de Chile
    Es un intento de Estafa
    Zanjado el tema
    Take care about this Fake Callsign
  8. F0DUW
    You dont understand, this is VIRTUAL, nobody will go on this island, its VoIP via internet, do you understand ?
    "HamSphere is a subscription-based internet service which simulates amateur radio communication using VoIP connections over the Internet. The simulator allows licensed radio amateurs and unlicensed enthusiasts to communicate with one another using a simulated ionosphere. It was designed by Kelly Lindman, a radio amateur with call sign 5B4AIT.
    The system allows realistic worldwide connections between amateur radio operators as well as radio enthusiasts. In general it is similar to other VoIP applications (such as Skype), but with the unique addition of characteristics such as channel selection by tuning, modulation, noise effects and shortwave propagation simulation.
    Before using the system it is necessary for a radio amateur's call sign to be validated. The HamSphere system relies on different amateur online callbooks for verification before his or her call sign is added to the list of validated users.
    The system may be used without a verified radio amateur license and has a callsign generator providing unique unofficial HamSphere callsigns.
    The software is written to run on Microsoft Windows, Apple OS X or Linux using Java. Also available are mobile editions of the software running on Apple mobile devices (iPhone, iPod touch, and iPad) available from the Apple App Store, and on Android devices from the Google Play Store. The software is available for download as a free trial, but requires a yearly subscription after the free trial expires."
    Source https://en.wikipedia.org/wiki/HamSphere
  9. F0DUW
    HamSphere es un software basado en la radioafición que permite a radioaficionados licenciados oficialmente y a cualquiera interesado en la radioafición comunicarse con otros utilizando una "ionosfera virtual" en la red, esto es, a semejanza de la ionosfera en el cielo donde las ondas de radio rebotan y permiten su captación mediante receptores, el software emula un transreceptor que emite y recibe mensajes en la forma en que la radioafición suele hacerlo, utilizando las líneas telefónicas como una ionosfera. Fue diseñado por Kelly Lindman, un radiaficionado con indicativo 5B4AIT.
    El sistema permite conexiones mundiales entre operadores de radio o aficionados entusiastas de radio a través de la banda ancha de Internet. En general el sistema es como otras aplicaciones VoIP (tales como Skype), lo novedoso es la simulación de propagación de onda corta en una pantalla que representa un transreceptor. Funciona como un chat de voz donde cada canal es un punto del dial en el que es posible la comunicación entre emisores y receptores, como en una comunicación normal entre radioaficionados. Emula a los chat de voz de Internet, pero mientras estos reflejan su actividad por el número de personas que concurren a una sala, en HamSphere la actividad sonora se refleja en la intensidad de la onda sin especificar el número de personas que concurren en el punto del dial desde donde se produce la comunicación. Se indica en su panel en forma de excitación de una onda de mayor o menor intensidad la actividad de la comunicación, de la misma manera en la que en un transreceptor se localizan estaciones desde las cuales se observa si existe actividad sea recibiendo o emitiendo para poder comunicarse con ellas.
    Antes de utilizar el programa es necesario registrar un indicativo tal y como los radioaficionados poseen cuando son licenciados, aunque es posible obtener un indicativo sin obtener licencia alguna. Hamsphere genera indicativos no oficiales que pueden coincidir con el verdadero indicativo de radioafición o no, por lo que su uso está abierto a cualquier usuario.
    El software está escrito para el sistema operativo Microsoft Windows, Apple, o Linux Java (software platform). Existe otra edición del software para móviles Apple (iPhone, iPod touch, iPad), aunque está en fase de desarrollo. Mientras tanto, la versión de Hamsphere actual parece que será sustituida por la 3.0 en breve, es un software de pago ( unos 25 € ) en desarrollo continuo con futuro y buena aceptación entre los usuarios de radioafición que se conectan a Internet.
    https://es.wikipedia.org/wiki/HamSphere
  10. F0DUW
    This call will be only used on hamsphere, not on real ham radio. Its a virtual ham radio vie internet
