Hello all, I allowed my Extra Class amateur radio license to expire, it expired in June of 2017. From what I understand, if I go to a VE testing session and take the Technician exam, I am within the grace period in which the FCC will grant me an Extra Class license - in other words I don't have to retest all the way up to Extra Class again. I would like a VEC to let me know if this is correct information. Also, I live in Philadelphia and would like to attend a ve session nearby, or I am open to the possibility of taking it remotely as I understand is now possible. Any help appreciated, Tim
No, you cannot. §97.21 Application for a modified or renewed license grant. (b) A person whose amateur station license grant has expired may apply to the FCC for renewal of the license grant for another term during a 2 year filing grace period. The application must be received at the address specified above prior to the end of the grace period. Unless and until the license grant is renewed, no privileges in this part are conferred. https://www.ecfr.gov/cgi-bin/text-i...mc=true&node=pt47.5.97&rgn=div5#se47.5.97_121 §97.501 Qualifying for an amateur operator license. Each applicant must pass an examination for a new amateur operator license grant and for each change in operator class. Each applicant for the class of operator license grant specified below must pass, or otherwise receive examination credit for, the following examination elements: (a) Amateur Extra Class operator: Elements 2, 3, and 4; (b) General Class operator: Elements 2 and 3; (c) Technician Class operator: Element 2. [65 FR 6550, Feb. 10, 2000, as amended at 72 FR 3082, Jan. 24, 2007]
Any help appreciated, SORRY TO READ ABOUT YOUR HEADACHES. OK... HERE IS A LIST OF ARRL AFFILIATED CLUBS IN YOUR AREA I would like a VEC to let me know if this is correct information. I WAS ABLE TO OBTAIN THE ABOVE INFO FROM THIS LINK: http://www.arrl.org/find-a-club THIS LINK IS REALLY GREAT BECAUSE IT HAS A VERY POWERFUL SEARCH ENGINE AND WILL FIND A CLUB VIA A.........TOWN NAME / ZIP CODE / AND WHAT NOT. IF TIME ALLOWS, I SUGGEST THAT YOU VERY CAREFULLY READ THIS LINK. http://www.arrl.org/news/anchorage-vec-asks-fcc-to-grant-lifetime-credit-for-expired-licenses FOR ADDITIONAL HELP REGARING THIS MATTER , CHECK OUT THIS LINK. http://www.arrl.org/contact-arrl 73 AND WELCOME BACK TO HAM RADIO. K1LKP
Yes, all you have to do is take the tech test, and provide proof that you previously held an extra license, you will be granted an extra. Make sure you check with the ve team doing the test so that you can bring the documents to them.
Hi Tim, There is no "grace"period for the application of previous license credit. So yes, you can take the Technician test (Element 2) and receive credit for Elements 3 and 4 upon presentation of evidence of an expired Amateur Extra license. §97.505 Element credit. (a) The administering VEs must give credit as specified below (see the chart at the link below) to an examinee holding any of the following license grants: (b) The administering VEs must give credit to an examinee holding a CSCE for each element the CSCE indicates the examinee passed within the previous 365 days. [79 FR 35291, June 20, 2014] https://www.ecfr.gov/cgi-bin/text-i...6236af4b&mc=true&node=se47.5.97_1505&rgn=div8 Make sure you check with the VE team leader prior to your test session to see what kind of documentation will required to prove your prior license status. Good luck and welcome back! Regards, -Bruce
