Making a new version of a wifi home status. The current board uses a Nodemcu fed info from a stand-alone 328P that is used to monitor some inputs and send info to the Nodemcu where its simple displayed on a webpage. Got a couple ESP32's and I'll be able to simplify things. Many advantages due to more I/O on the esp32, down to 1 processor, able to use 2 pin change IRQ's and the Timer IRQ, at least 3 Voltage measurements (for now) - basically more I/O and bluetooth (if I ever get a cell phone) Made the web screen with LED indicators which I may change to small icons of devices monitored. Still have the serial for monitoring at least for development. The board is going to be simple, a few optos & voltage dividers plus a 3v3 wall wort Not sure if I'll actually be able to use the ultrasonic module, it works great on the desktop however, theres too much physical interference in the sump pit to get a good reflection. The pvc sump pit walls, 110vac & 12v backup pump dont give enough water area to get a good reading. I was hoping to use ajax or java to just update the inputs but nothing on this setup needs to report instantly - every minute or 30seconds would be soon enough, all the monitoring of inputs is calculated in the main loop, besides I'm no expert with that code. STILL
I made the mistake of buying 1 ESP32. I should have bought 4, a mistake I will rectify later today. One radio equipped ESP32 is like one hand clapping. ( Side note: if I find the sadistic SOB who invented auto-correct I will fish slap him with a tuna. I had to correct about a dozen auto corrections in that sentence ). Have you discovered the Keyestudio ESP32 IO shield, and the I2C interface conversion shield?
No I haven't seen those, nice add-on. Normally, I mount the wifi chips on a pcb with the finished I/O. I'm still using thru hole for my boards since I've a good inventory of parts for that I should get a few more of the esp32's as well, they are quite versitile. One thing thats on the back-burner is using a couple nodemcu's to send & receive between my rotor slave and master unit. It uses 9600 8n1 with text commands and it would be great to remove another wire from the shack. Going to try and use the ESP-NOW code. Experimented having 2 talking back & forth a few weeks ago, just need to program them as serial bridges.
fixed up the code for the home monitor yesterday, One rabbit hole I fell into was cut and pasting example code into this project. worked perfectly except when calculating change in pump intervals, a negative would always show on the web page as some huge positive number After several hours of breaking down each line, following variables thru the program flow and looking up assigning variables (again) the solution became obvious. The variable used in a client.print statement was declared as an unsigned long took off the unsigned and all is good. Not totally versed in arduino C but able to eventually figure syntax out.
