Electronics & Radio - Reducing the noise from my camper's LED lights.
Discussion in 'Amateur Radio News' started by KB7TBT, Jan 15, 2020.
  1. KB7TBT
    KB7TBT Ham Member QRZ Page
    KC1CSG, VE7PBF, ZL2SCI and 9 others like this.
  2. KK4NSF
    KK4NSF Ham Member QRZ Page
    That's a great video, and helpful. Unfortunately it doesn't solve the real problem: manufacturers using cleap, chinese made parts that do not meet FCC requirements.... even in campers that cost a LOT of money. My own little trailer is very quiet, but when we take it to a crowded camp ground you can barely use the radio. The QRM from all of the other campers drowns out virtually all of the incoming signals. It sounds like some sort of Russian Jamming!
    KJ6NQW, KD0CAC, KG7HVR and 3 others like this.
  3. N5WX
    N5WX XML Subscriber QRZ Page
    I also had a very noisy AC/DC converter which I replaced with an Alinco 30 AMP supply. Thanks for your video.
  4. K5VJZ
    K5VJZ XML Subscriber QRZ Page
    I too was plagued with noise from the LED lights. I replaced all the fixtures using fixtures that would take an 1141 LED...
    Noise is now gone ! next stop is to do as Ron did, change the AC/D converter.
  5. K3XR
    K3XR Ham Member QRZ Page
    I've not noticed LED light problems in my R-Pod trailer but had some noise from the AC/DC converter also. I replaced the entire board with one from another manufacturer that was made to fit and it's much better on noise. The original converter developed a charging problem just out of warranty and was the main reason for the replacement. I am something of a fair-weather camper so most of my operating is outside the trailer and the noise seems to vanish rather quickly as you move away from the converter.
  6. PA0MHS
    PA0MHS XML Subscriber QRZ Page
    You need to realize that FCC rules do not limit RF emissions to zero nV. A device can radiate withing FCC limits and still mute your radio if you're close enough.
    W3CUB likes this.
  7. KB0MNM
    KB0MNM Ham Member QRZ Page
    Related info: ( This is not to be construed as anything but an observation which pertains to LED noise, precedents, and enforcement )- not my opinion: ( version has edits for brevity and legal - privacy reasons ) :
    Federal Communications Commission DA 13-2077 Before the Federal Communications Commission Washington, D.C. 20554
    ( removed cited party name for legal reasons- pubic domain) File No.: EB-FIELDSCR-13-00010114
    Citation No.: C201432540001 San Antonio, TX - Houston Office FCC )
    CITATION AND ORDER Incidental Radiator Causing Harmful Interference
    Adopted: October 25, 2013 Released: October 28, 2013
    This should still be on the books, just applies to 700 Mhz. band- an example that the FCC does sometimes take action.
    W7SJP, WN1MB and WQ4G like this.
  8. K0UO
    I go to Quartzsite Arizona most every year and as soon as it gets dark everybody turns their LEDs on. 20 over 9 noise
    Then after they go to sleep it's very quiet.
    But at Sunrise their solar controllers kick on and everybody turns their inverter generators on and their LED lights again.
    20 over 9 noise.
    It used to be extremely quiet in the desert!
    KB7UXE likes this.
  9. KI7OQF
    KI7OQF Ham Member QRZ Page
    My noise was my computer,,its full of LEDs
  10. N4EYZ
    N4EYZ Ham Member QRZ Page
    Great video and very helpful!
    Wayne
    n4eyz
ad: AlphaRF-1
