Can I just plug this in to my Yaesu FTdx-101MP with the Heil XLR to Yaesu cable, without needing to first go through some sort of external cloud lifter or pre-amp? I've had a couple of these mics sitting around for awhile and thought I'd go ahead and install one for my HF setup. I also have a Shure SM7B I could use as well, but prefer the articulation for voice of the RE20 over the SM7B. Alternatively I'd considered using the dbx 286s as a go between, but would rather put as little in my audio chain as possible. And I don't really want to make room for the dbx 286s. Thanks for your time!
Start by obtaining and reading the spec sheets for the equipment. http://recordinghacks.com/pdf/ev/RE20-EDS.pdf Impedance: 150 Ohms. Phantom/Bias Power: No.
For those of us who aren't familiar... "Cloudlifter", proprietary brand of inline, mic-preamp powered by phantom https://www.musiciansfriend.com/pro...TY47AICp1w1yIzOh6Bso0rhR4cbzHgPxoCLScQAvD_BwE
Instead of a Cloudlifter I use a Klark Teknik CT-1, much less expensive and works great. I use it to boost my dynamic mic to use with a IC-7300. Only Con is, it needs phantom power to power it, luckily I had a $18 phantom P/S already, Nady brand. I think the RE-20 should work, output is 1.5mv. That is probably mid-range power for a dynamic mic so the Yaesu mic preamp should handle that. Dave
Excellent microphone. Make sure you DO not activate any phantom power to it. Not needed. Once you get it matched with your transceiver, have a look at a scope, preferably on AM, and make sure the phase of the mic is correct. You probably know that Pin 2 of the XLR is "hot," such that positive pressure on the mic diaphragm = positive leading sine wave. That should be the case throughout the chain. If not, swap the balanced pair anywhere and have another look.
Thanks for the invite, and yeah the EV RE20 is a fantastic microphone. I knew about the XLR cabling, and as far as matching goes, the RE20 is 150ohms and from what I can see all the Yaesu microphones are 300 ohms, so the RE20 is going to be louder. I'm going to see if I can adjust the volume in the radio since it comes with a microphone processor/compressor and EQ. If not I'll look at a matching transformer to step it up to 300 ohms.
Louder? Not sure you can use impedance to compare the likely loudness of the EV vs. a Yaesu microphone. I presume the setting of your mic gain control would depend on the voltage output of the microphone into its matched load impedance. You could have two 150 ohm mics, for example, into a 150 ohm mic input of a mixing console, and the amount of gain the console applies could be different to reach the desired level. A higher output level is one of the advantages of the Electro-Voice RE-27N/D compared with the older RE-20. The impedance is the same, but your audio chain can sound better because of less initial amplification needed. Using really good microphones in the hobby is a satisfying aspect that more and more people are discovering. The pleasure comes not only from addressing a substantial, nice looking, "broadcast" quality microphone, but also the technical pursuit of making such a microphone work well into a hobbyist-type radio. Have fun, that's the goal, right?
If your goal is having fun using studio mics and audio chain to adjust processing, levels and frequency response. This is just another aspect of the hobby. The realization is that you won't get the full capability of broadcast quality equipment due to the fact that most modern transceivers transmitter audio bandpass is restricted by the software.
Yeah the audio on this rigs is pretty limited compared to the microphone itself. Rigs like the Icom 7610 hard limit you (as far as I know) to 2.7Khz and even eSSB capable rigs like Kenwood TS-890s or the Yaesu FTdx-101 series your pretty much limited to a maximum of 3.4KHz-4KHz so I'm not expecting miracles. This is mostly for fun and I already owned the microphones and thought I'd add one to the shack just to complete the look on this end.
"The look" is a significant part of the operating experience! I smile when people question the use of professional-grade components in our "amateur" setting, after all, it's up to the user to decide where the enjoyment comes from. Hope to hear you on some time. I traded an RE-20 toward the RE-27 when it first came out. Electro-Voice, through its retailers like broadcast equipment suppliers, offered to take an RE-20 and $100 for a brand new RE-27. The marketing promotion was to help get the new model out there. I was quite happy with the change. Their offer was enough to motivate me to try it, otherwise, the '20 was/is also a fine microphone for vocals.
You can't go wrong with the Electro-Voice RE20 it's been a mainstay in radio and voice-over work since pretty much it was released back at the end of the 60's. I've not really played around with the RE27 but I've never heard anything bad about it. When it comes to voice work professionally I think my go-to's would be the Shure SM7B or the EV RE20 though the SM7B is more versatile than the RE20. But to be honest the Electro-Voice RE20 just looks better and my reason for choosing it for my shack is because it just fits the look I wanted. I wouldn't of bought it for amateur radio but since I had it I thought why not give it a go. My initial go is going to just try hooking up straight to the radio and use the controls inside the Yaesu FTdx-101MP if that doesn't pan out I will try using the dBx 286s in front of the radio since I have a few of those. Failing that I might just get the Yaesu M-1 microphone or the M-100 and be done with it. I don't think you can go wrong with either of those.
I had a hard time deciding between the re20 and re27. I went with the 27 because I thought the brighter mic might be better for ham radio work. I can't answer the original question since I use outboard audio gear. BTW, a mic preamp can easily be connected to the data port and will let you use any mic you want. The only issue you may have with connecting a studio mic to the mic jack on the rig is not having enough gain. I plugged a PR40 into my FTDX1200 and it worked well on SSB, but the compressor had to be turned on or the audio level was too low. The bad part is the compressor can't be turned on in AM mode. It wouldn't make 100% modulation without holding the mic against my tonsils and yelling.
Thank you for the info, do you have a link you could possibly share with regard to hooking up a preamp to the data port? See I've been concerned about gain and have assumed I would end up using the dBx 286s as an external preamp + compressor but haven't wanted to go down that path just because the dBx 286s is on the larger side (as compared to the width of the radio and amplifier) and is usually rack mounted so it's a bit clunky. I've also concerned using my PC mic preamp and just assigning the radio mic to a line out from the preamp, but again that's just clunky. I like the idea of using the radio to power a preamp of some sort and keeping it as compact as possible.
I don't have a link but what you'd be doing is similar to connecting the sound card from a pc to use digital modes. The manual should show you where to make the connection. Be sure to use an isolation transformer if you go this route. Also make sure you can change the audio input from mic to data in the phone modes. It's in the menu on the ftdx1200 but I have no experience with the rig you have.
