Elecraft K3S and Heathkit SB-200 hookup advice
Discussion in 'Amateur Radio Amplifiers' started by N8MDC, May 8, 2021.
  1. W1QJ
    W1QJ Ham Member QRZ Page
    You specifically said +200 volts. I’m saying it’s a minus voltage that’s all.
  2. K2XT
    I was just quoting the manual. Let me get right on this. We can't let this issue hang. The whole ham radio world is waiting.
  3. K2XT
    My goof in assuming the K3 key out was a relay contact. It actually uses an IRF1630 FET to key the key out line.
  4. KD2ACO
    Well, that FET would blow its top! :p
  5. W4HWD
    W4HWD Premium Subscriber QRZ Page
    You could also call Elecraft and ask them.
    That would be preferable to messing up something in a rig that can't be replaced cos it's out of production.
  6. WB2WIK
    I'd use the ARB interface here; or better still, if one doesn't mind the slight additional delay, just add a small 12Vdc relay inside the amp whose coil is powered by a voltage doubler from the filament circuit and whose contacts key the original relay and make the amp "universal" so it can be used with any kind of transceiver and without the external interface.:)
  7. K2XT
    OP said he has it working. Presumably with the Ameritron interface unit.
