Echolink wont connect after Fiber Optics installation
Discussion in 'Echolink/IRLP Tech Board' started by N6HBJ, Jun 17, 2017.
  1. N6HBJ
    N6HBJ Ham Member QRZ Page
    Hello.
    My cable company switched to fiber optics and installed it in my home including a new modem. Ever since then, my Echolink cannot connect to anyone including the test server. We have bypassed my router as well as disabling Windows firewall to no avail. My cable company told me there are no ports in their modem.
    I have no clue what to do next.
    Mike N6HBJ
  2. KA9JLM
    You have to forward the ports in their router not the modem.
    Do you know the model number ?
    Is it AT&T ?
  3. N6HBJ
    I have my own router which has been set correctly. They did not add an additional router. They switched their old modem for a new one. From there it goes to something called an optical node and then to the outside...
  4. KA9JLM
    What is the make and model number ?
  5. N6HBJ
    Their modem is a Calix GigaPoint 810G. Model no. is 100-04253 10
    The optical node is a MACOM MX700-4AC
    My old router is a Linksys and has been working fine for years.
  6. KA9JLM
      • On your local PC, open a browser window and enter the IP address of the GigaPoint's management interface:
        http://192.168.1.1
      • Enter the default login credentials to gain access to the EWI:
        Login: admin
        password: admin
    Embedded Web Interface
    The Embedded Web Interface (EWI) is available for viewing and managing GigaFamily devices through your personal computers browser. The EWI allows you to login into any Home Gateway connected GigaFamily device using its IP Address and the appropriate login credentials. Once connected, management of the device can be executed from your desktop.
    In the following pages, a high level overview of the EWI is presented. Links are also provided that will allow you to drill more deeply into each item with specific field definitions for all displayed options.
    The Home Gateway partition of GigaFamily devices is managed through the Embedded Web Interface (EWI) and includes the following deployment options presented as menu items in the top navigation bar:
  7. N6HBJ
    Here is a picture of it. I'm not very computer savvy. Not sure what to do now.
  8. KA9JLM
    So it is 801, Not 810
    1. On your local PC, open a browser window and enter the IP address of the GigaPoint's management interface:
      http://192.168.1.1
    2. Enter the default login credentials to gain access to the EWI:
      Login: admin
      password: admin
      http://192.168.1.1
      Login: admin
      password: admin
  9. N6HBJ
    That's the same IP address as my Linksys router so it defaults to that. I tried the "admin" log in password to see if it would log me in the other device but no luck. I wonder if I need to bypass my router temporarily?
  10. KA9JLM
    I would try that.
    Two devices with the same IP on the same network will not work very well.
