EchoLink reporting wrong local IP address?
Discussion in 'Echolink/IRLP Tech Board' started by N5BCN, Oct 30, 2017.
ad: OK1UUad-1
  1. N5BCN
    N5BCN Ham Member QRZ Page
    EchoLink is currently working fine on my Win 10 box and passes the Firewall/Router Test.
    However, the Firewall/Router Test reports a "local IP address" of 192.162.56.1. The issue is my home network (obviously including the Win 10 box running EchoLink) is NOT a 192.162.x.x network.
    Considering EchoLink runs perfectly fine, I'm confused why this would be. Any insight would be appreciated.
  2. KA9JLM
    That IP is most likely the IP address that your ISP assigns to the router.
    If you ping 192.162.56.1 do you get a response ?
  3. KD4MOJ
    KD4MOJ Premium Subscriber QRZ Page
    Interesting... it's a Russian IP block. Are you sure it's not 192.168.56.1?
    ...DOUG
    KD4MOJ
  4. K8ERV
    K8ERV Ham Member QRZ Page
    Dynamic IP?
    TOM K8ERV Montrose Colo
  5. KA9JLM
    Probably a Russian Proxy. :rolleyes:
  6. N5BCN
    Oops, yes that was a typo, it's 192.168.56.1. No Russian invasion (yet).
  7. N5BCN
    My router and home network are on a 10.x.x.x network so the router (via DHCP) give out 10.x.x.x addresses (I changed it from 192 for VPN purposes). That's why I'm not understanding why EchoLink is reporting a 192.168.x.x address. Maybe it assigned this to itself? The machine that's hosting it is a 10.x.x.x address. I pinged 192.168.56.1, no response (it shouldn't get a response since it's on a different addressing scheme). Very strange.
  8. KA9JLM
    192.168.56.1 should be a gateway.
    Try "netstat -r" from the command line. See what it tells you.
  9. KD4MOJ
    Well at least it's working. Maybe it was just reporting the old 192.168 address that you used.
    ...DOUG
    KD4mOJ
  10. KB3VWG
    KB3VWG Ham Member QRZ Page
    Open the Command Prompt and enter:
    See if any listed network card has that assigned IP address.
