Easy Digi to Jupiter wiring
Discussion in 'Working Different Modes' started by KF4ZGZ, Feb 11, 2019.
  1. KF4ZGZ
    KF4ZGZ Ham Member QRZ Page
    Anyone have wiring in for interfacing an Easy Digi a Ten Tec 538 Jupiter.
    I want to go through the ACC 1 jack on the back of the radio.
    The ACC1 jack is simple.
    Pin 1 = audio "in"
    Pin 4 = audio "out"
    Pin 3 = PTT (close to ground to transmit)
    From the MENU, select AUDIO SOURCE, then select LINE
    Done!
  3. K6CLS
    K6CLS Ham Member QRZ Page
    Not quite done, which pin is ground?
  4. W5DXP
    W5DXP Ham Member QRZ Page
    It's a lot like my IC706. Here's a schematic:
  5. WB2WIK
    Yes, it's exactly like that.
  6. KF4ZGZ
    Thanks .... You guys rock.
    I'll admit to being lazy ..... I had taken a quick look and had it figured out ... but wanted to be sure.
    Now living the frustration of digging thru the junk box ...... all kinds of plugs ..... but not the accy 1 5 pin. :(
  7. KQ4MM
    KQ4MM XML Subscriber QRZ Page
    Matt,
    Guess what I found ... the original 5 pin DIN to 4 phono plug cable that came with the Jupiter .. if you want it let me know and I will shoot it your way ... no charge...
  8. KF4ZGZ
    Sure! Save me some burned fingers!
    Thanks!
  9. KQ4MM
    I will get it in the mail tomorrow and send you a tracking number once I get it ...
  10. KF4ZGZ
ad: Amateur-1
