Drake (T-4XC) T-coils dot colors
Discussion in '"Boat Anchor" & Classic Equipment' started by PA9Z, Dec 3, 2021.
  1. PA9Z
    PA9Z Ham Member QRZ Page
    Hi Forum
    While re-aligning my Drake T-4XC, the manual says (page 5-2) that the slug alignment position depends on the color of dot on top of the slugs of T4-7. Now 3 of the slugs have off-white dots (the dot of T6 is missing), but they may also be pale yellow.
    My question: how yellow are the yellow dots? Bright yellow or very pale?
    '73 Rob PA9Z
  2. WA1GXC
    WA1GXC Ham Member QRZ Page
    I would recommend that unless absolutely necessary to adjust the coil-slug screws due to prior misalignment or tampering by a previous owner, do
    not adjust the screws in any way. The ferrite slug/screw assembly is somewhat delicate and if frozen and you do not want to risk damaging it.
    There should be enough adjustment-range utilizing the RF trimmers/Injection trimmers array on the side of the transmitter--adjusting for every band
    during this same procedure--to bring all transformer circuits--T4, 5, 6, 7 into resonance.
    If you find you require maximum capacitance (fully tight adjustment on any trimmer), you may re-position the "RF TUNE" control to very slightly lower
    frequency on any band with the front-panel control--that will give more inductance--and you will be able to re-adjust the associated trimmer capacitor to a less-tight
    position to achieve resonance and maximum drive power.
    If you look at the very small dimension differences in the manuals--white dot, yellow dot, etc.--you will see it is not even 1 mm difference. I know I cannot
    reliably measure that adjustment precisely with the transformers installed in-place.
    I suspect your off-white dots are faded yellow with age. Measure the lengths and if they seem
    reasonable, in accordance with specifications, just proceed as above with trimmers.
    Good luck!
    Doei
    K7TRF likes this.
  3. PA9Z
    Thanks Harris again for your good advice. Indeed, I did not touch the sealed screws of the individual slugs, I only adjusted the whole beam connected to the wired mechanism.
    Indeed the differences of the settings between the various coloured slugs is minimal. I wondered why there is a difference in the adjustment settings anyway.
    In the mean time I was able to adjust the coils. I also replaced the two finals and the rig is now producing a nice 100W+
    73 from the Netherlands!
    Rob
