Drake L7 ps upgrade
Discussion in 'Amateur Radio Amplifiers' started by W1CJF, Mar 15, 2018.
  1. W1CJF
    W1CJF Ham Member QRZ Page
    I just purchased a nice drake L7 with emiacs tubes. It has the harbach upgraded board in it. I am looking into getting the Peter Dahl upgraded transformer for the power supply and wondering if anyone ran the upgraded one. I'll be doing a lot of AM so that was one reason and the stock one is good I would just like to have a little overhead for am. I'll have to get it built but seems like a good investment for these amps. Thanks
    Chris
    W1cjf
  2. WB1E
    WB1E Ham Member QRZ Page
    Chris,
    2400 volts @ 800 mAmps is what Drake states in the manual as full voltage & current. Dahl does make custom builds, don't they have something already?
    Mine is coming along, but yes, the HV Xmf may be temporary. The MFJ AL572 replacement transformer ships for less than $200 and comes with 2800 @ 800mA. I used one for my Cliperton L. Also has a 12V & 6V (6V with CT) windings. Has some buck-boost primaries even. http://www.ameritron.com/Product.php?productid=406-1572
    The CJ plug is full up however.
  3. W1CJF
    This is the one from dahl... aka hammond. I didn't know mfj also made one. 1170/870 vac. I just want 3k+ on the plates to make them tubes come alive.
  4. WB1E
    I read this list today, looks like PD makes a dozen different transformers for the L4B! You'll find it down the list here http://www.pwdahl.com/PWD_HamCatalog.html
    DRAKE L4B-XB-M
    FOR USE WITH BRIDGE RECTIFIER
    CORE) A-480 C-CORE STYLE #) 10 HIPERSIL C-CORE
    PR) 117/234 VAC 60 HZ WITH HI-LO TAPS
    S1) 1700/2300 VAC @ 1.0A CCS
    DM) HT = 8.375 WT = 8.075 DT = 7.688 MD = 3.937 MW = 5.500
    PRICE) CALL or e-mail Plus S&H FOB Buffalo, NY WEIGHT) 46 LBS
    Good luck !
  5. W4DRA
    W4DRA Subscriber QRZ Page
    I just rebuilt my PS for the Drake L7. After the bigger transformer from Heybour in Mi.
    It now supplies a full 3200v in CW and 4000v in SSB. This thing is a 1.5 amp. I also rebuilt
    the Harbach board with 600v 220mF caps with 5 watt resistors along with 6 amp diodes. I brought the new
    3-500zg's to life. I get full legal limit on CW position with 65 watt drive.
    HOWEVER I get a pretty big voltage drop on the Plate still. It drops about 400-500 volts just keying
    the amp with no RF. Anyone have any idea why this is so much?
    My supply line voltage stays at 235v with no drop. The AC voltage out on the transformer drops about
    25-30 volts before going through the caps and diode rectifiers.
    I have a big metal cabinet for this but wanted to ask before I mounted the transformer @ 57lbs. so as not to
    have to pull it out again. This really has me stumped and don't know where to go from here.
    Any help will be greatly appreciated.
    Thanks
    Dave
    W4DRA
    w4dra.dave@gmail.com
  6. W1QJ
    W1QJ Ham Member QRZ Page
    400-500 volt drop with just idle current is awful regulation. I would expect a 500 volt drop at full power output, but not at idle current. If your line voltage is not sagging you have a problem someplace. a bad filter cap perhaps? That needs to be looked into. A big heavy duty transformer like that should not sag that much. Also, due to the odd configuration of the Drake transformer primaries it is not a "walk in the park" to retrofit an Ameritron transformer unless you completely understand what you are doing. Drake does not had a typical primary configuration.
    W4DRA likes this.
  7. W9JSW
    W9JSW Ham Member QRZ Page
  8. WA7PRC
    WA7PRC Ham Member QRZ Page
    At 1500W output and about 50% efficiency (a little better at low frequencies), expect to pull close to 3000W on peaks. Heathkit and others got by with a smaller transformer because the intended use was SSB (about 25% duty cycle) and Morse (about 33% D/C). They relied on sufficient C in the filter to supply peak current. It works but, forget about running any high D/C modes.
    Bryan WA7PRC
    http://www.tinyurl.com/wa7prc-transformer
  9. WB2WIK
  10. WA7PRC
    According to the catalog, it can source up to 2570 Vac @ 0.8A (2056 VA).
    I looked at that but, when I realized I had a much better transformer (about twice the VA) that needed only rewinding, I spent about 1/4 the cost of that Ameritron unit. It was fun, too. :)
    Bryan WA7PRC
