Dongle don't dingle no more since I moved it to a hub. :(
Discussion in 'Computers, Hardware, and Operating Systems' started by AA9G, Dec 13, 2019.
  1. AA9G
    AA9G Premium Subscriber QRZ Page
    So I had to move my sdr dongle from direct connect to a powered USB hub. Only now no software I have will start. Console, SDR#...nadda. I've reinstalled Console. I've re run Zadig. I've rebooted the computer. I've uninstalled everything and started from scratch. What am I missing here? Using Win 7 Home.
  2. KV6O
    KV6O Ham Member QRZ Page
    Bad hub? Is the dongle showing up in device manager?
  3. AA9G
    Hub is fine. Everything that I can check appears normal. :(
  4. KJ4VTH
    KJ4VTH Ham Member QRZ Page
    Connect it direct, does it work again?
  5. KA9JLM
    How much power does your hub provide on the port you are using ?
    What kind of hub is it ? USB2 or 3.
    Some USB3 hubs only have 1 or 2 ports that provide full power.
    You say "Only now no software I have will start."
    The software should still start, Even if the Dongle is unplugged.
  6. AA9G
    If I plug the dongle directly into the computer it works fine. The hub provides 5v to each port. I only have the dongle plugged in. When I say the software won't start I mean when I press the start button in the program nothing happens. The program itself does open.
  7. N3DT
    N3DT Ham Member QRZ Page
    I have found that issue with hubs. Sometimes they work and sometimes not. Might have to try a different brand.
  8. K3XR
    K3XR Ham Member QRZ Page
    SO Guess it didn't dingle all the way.
    AA9G likes this.
  9. KA9JLM
    5 Volts does not mean a lot, Depends on the load.
    Most SDR dongles that I have tested require 600 mA or more, Just above the 500 mA that most USB ports provide.
  10. AA9G
    :D Nope. There is something wrong with that specific usb port, which is located on the front of the case. I got an extension and plugged the whole operation into a port on the back of the computer and it's been running perfectly for days now.
    K3XR likes this.
