Does the ts-890s have an easy to replace clock battery
Discussion in 'Ham Radio Discussions' started by KF6OCI, May 25, 2019.
  1. KF6OCI
    KF6OCI Ham Member QRZ Page
    wondering if the ts-890s has a soldered in clock battery, or an easy to replace one, if at all.
    thanks
  2. N4GKS
    N4GKS Ham Member QRZ Page
    I think they’re good for about 20 years.
  3. KF6OCI
    kenwood has radios with user replaceable batteries, would you like to know if the ts-890s is user replaceable or soldered in.
    Thanks
  4. G3ZPF
    G3ZPF Subscriber QRZ Page
    I've looked through ts890 user manual and in-depth manual. No mention of a battery for the clock. It does say the clock can be set to auto correct if there is a PC connected to the rig, using an NTP time server. I have not had the case off to look inside.
    My old ts930 did have removeable batteries for the clock & memories, (4xAA which you accessed through a lil trapdoor) but I found that providing the rig was turned on at least once every 2 weeks you didn't need the batteries. There was a tantalum capacitor in there which would hold a charge for that long.
    NL7W likes this.
  5. WA9SVD
    WA9SVD Ham Member QRZ Page
    The schematic and/or parts list should tell you if a rechargeable battery is used, and what type. Accessing the battery (often requiring partial disassembly) is often harder than the actual replacement.
  6. KA9JLM
    No user replaceable parts inside. o_O
    A super cap only provides power for a short time.
  7. KF6OCI
    Are you sure about that, i like that.
    Thanks Everyone!
    !!! i like the super cap,
    should last forever.
  8. WA9SVD
    A "Super Cap" may last forever (or almost forever,) but its charge will NOT. A similar cap in a So*y alarm clock radio holds a charge for only a few hours, enuf to last only a short term power outrage.
  9. WA9SVD
    Rechargeable and "user replaceable" are not synonymous. Even taking the case apart and not making any mods can void a warrantee, and "no user replaceable parts" is boilerplate for almost ALL things now available to consumers. Even adding filters to some modern radios void a warrantee if not installed by a $$$ paid factory trained technician.
  10. G3ZPF
    Well, as I said, the tantalum capacitor in my old ts930 held its memory settings (there was no clock) for 2 weeks. When I go on my summer holidays I'll see if the ts890 clock is still on time when I return. The rig will be powered down for the duration.
    "...The schematic and/or parts list should tell you if a rechargeable battery is used..."
    Yes, that was my assumption, but on a first read through I couldn't find reference to it.
