Do You Own a Dummy Load ?
Discussion in 'Survey Center' started by NN4RH, Dec 25, 2020.
Do you have a dummy load or can get one easily ?
  1. Yes.
    115 vote(s)
    87.8%
  2. No, but I know who does and I can borrow it easily.
    2 vote(s)
    1.5%
  3. No, but I'd buy one if I ever need it.
    8 vote(s)
    6.1%
  4. No. I will never use a dummy load.
    2 vote(s)
    1.5%
  5. No. Never thought about it before.
    2 vote(s)
    1.5%
  6. What's a dummy load ?
    2 vote(s)
    1.5%
ad: QSOToday-1
  1. K8PG
    K8PG QRZ Lifetime Member #333 Platinum Subscriber Life Member QRZ Page
    How abt AMATEUR RADIO
    NOT HAM
    CAPS .... OHHHH MY.
  2. KF5LJW
    KF5LJW Ham Member QRZ Page
    Yep built into the service monitor and a bird.
    PU2OZT likes this.
  3. PU2OZT
    PU2OZT Ham Member QRZ Page
    Ahahaha Between the Isotron, 160m and HAM, poll 'bout innocent DLs gonna be locked after a two-page run :D
  4. K0UO
    Yes
    It is between my two ears, and It's full of diathermic oil called Gray matter.
  5. K1SZO
    K1SZO XML Subscriber QRZ Page
    Where is the option, Yes, I use it as fireworks on July 4th by sending 5kw through it.
    PU2OZT, KU4X and K0UO like this.
  6. W4KJG
    W4KJG Subscriber QRZ Page
    I have no idea how many I actually have. They range from 5 - 25 watt units made by Narda. I've got one that looks like an old steam radiator made by Sierra Microwave. It says it is rated at 100 watts, but I'm guessing it would take a lot more for just a few minutes or to. And I've got two homebrew loads made in quart cans. One filled with Automatic Transmission Fluid and the other with mineral oil. The first one has four 100 watt/50 Ohm termination resistors in series parallel. The other has a single 100 watt 50 Ohm termination resistor. One resistor in a quart can barely gets warm after 5-10 minutes at 100 watts.
    K0UO and PU2OZT like this.
  7. K8PG
    I have a Heathkit Cantanna and a
    Palstar 2500 ? w dummy load.
    I always tune into them first , then
    tweek the amplifier on the air. My
    elmer K8DD had 3.
    Paul K8PG
    K3XR and PU2OZT like this.
  8. AE1N
    AE1N Ham Member QRZ Page
    OOPS, I WAS OFF THE DUMMY LOAD!
    ---Layne AE1N
    PU2OZT likes this.
  9. KA9JLM
    This is a Question that should be on the FCC test.
    If You Pass You get a Dummy Load as a prize. :)
    Some operators are a Dummy Load. o_O
    K8PG likes this.
  10. K7JEM
    K7JEM Ham Member QRZ Page
    You can buy quarter watt dummy loads for a penny each, but you have to install your own connector.
