Dentron GLT1000C
Discussion in 'General Technical Questions and Answers' started by KM4BJV, Jul 31, 2016.
ad: OK1UUad-1
  1. KM4BJV
    KM4BJV XML Subscriber QRZ Page
    Does anyone have a manual for this tuner ? I would like to get my hands on one or even a photo copy
    one one
    Thanks
    Mike
    KM4BJV
  2. W9GB
    Dentron GLT-1000C Antenna Tuner (160-10 meters)
    Front and Inside Views
    Let's describe, what is Inside the Box.
    Upper Right corner is PC board for your Wattmeter RF sampling board.
    Across the Back Panel are 5 different Antenna choices,
    and 1 Coaxial Input from HF transmitter.
    The 5 Antenna Inputs are: 3 Coaxial, 1 Long-Wire, and 1 Balanced Feedline.
    The Upper Left corner is the Balun for that Balanced Line.
    At the front panel, you have 2 variable capacitors (Input and Output), and
    a Toroid with Switch (Switching Inductance). Switch settings (A-L).
  3. KM4BJV
    Thank you for your reply
    Do you happen to have a manual.
  4. W9GB
    No.
    I have not seen a scanned version posted to Internet.
    You need to determine (reverse engineer) what type of matching
    this Dentron GLT-1000C Antenna Tuner uses.
    Different Types of Antenna Tuners / Matching
    by VK6SC
    Since you have 2 Air Capacitors (In/Out) and a switched Toroid Inductor (instead of a Variable Inductor) it is likely wired as a
    High Pass T-match Tuner (most common).
    The other 2 built-in functions, as noted earlier, are:
    A 5-position Antenna Switch (with a Balun on the Balanced Line choice) and
    Average Power Meter, Power level and Reflected.
    Antenna Tuners (Antenna Couplers)
    by Larry Benko, W0QE
    High-Pass Tee Network starts at Slide 37
    http://www.w0qe.com/Papers/Antenna_Tuners.pdf
    Impedance Matching 101
    by Ward Silver, W0AX
    Pacificon 2012 (Video is 57:24 in length)
    Ward starts to discuss T-networks at 33:00 (time mark).
  5. KA0HCP
  6. KM1H
    KM1H Ham Member QRZ Page
    Is it the same as the earlier AT-1000? That one is listed on Mods DK
  7. KC4UBC
    KC4UBC Ham Member QRZ Page
    I've been looking for the user manual for about 10yrs now with no luck at all. I think they closed the doors before they printed a manual. Hey, should you run across one share that baby with me and I'll do the same for you.
    kc4ubc Bill
  8. KM4BJV
    I will be happy to Bill . I am afraid we are out of luck
    KM4BJV Mike
  9. W9GB
    What Questions will the Dentron Manual Answer, that you can not determine from “root sources”?
    How to DIY Build a T-Match Antenna Tuner
    by VK6YSF
    https://vk6ysf.com/t-match.htm
    He used a Roller Inductor, and Dentron used a switched Inductor (Toroid).
    Getting the most out of your T-Match Network Antenna Tuner
    by Andrew S. Griffith, W4ULD ... Morehead City, NC
    QST magazine, January 1995, pages 44-47
    http://www.arrl.org/files/file/Technology/tis/info/pdf/9501046.pdf
    T-Network Tuner Simulator
    by Kevin Schmidt, W9CF
    http://fermi.la.asu.edu/w9cf/tuner/tuner.html
    Antenna Tuner — Wikipedia
    https://en.m.wikipedia.org/wiki/Antenna_tuner
    KD2ACO likes this.
  10. W5LZ
    W5LZ Ham Member QRZ Page
    In other words, no one has a manual for your tuner. I don't either. I think your best bet, maybe not the simplest, would be to trace out your tuner's circuit and make your own manual.
