ad: GNOHF-1
CW Morse code trainer Koch Method apps for Android
Discussion in 'Ham Made Gear' started by KG9E, Sep 4, 2018.
  1. KG9E
    KG9E Ham Member QRZ Page
    These Android apps will train you to hear Morse code at 10-30 WPM using an approach very similar to the Koch method.
    In this approach you learn first the vowels, starting with "a", then alphabetically the letters and ordinally the numbers.
    As you gain more experience copying Morse code, you will begin to recognize short strings of characters such as
    "CQ", "73", "Tu", "Tnx", "HiHi", "599", "Wx", and the numerous Q-codes.
    This app may be of interest to amateur ham radio QRP and QRO operators and CW or telegraph enthusiasts.
    10, 15, 20,25, and 30 WPM versions of this app are available on Google Play and Amazon Appstore.
    For learning the sounds of the characters you are presented with a game-like interface using a QWERTY keypad
    or the Default keypad, depending upon your choice.
    A character is played in Morse code, and you must tap the matching character on the keypad. Note that only the
    characters you have learned will be enabled. The game is very easy at first as you only have the letter "a"
    available to tap, but it quickly gets interesting as you progress and learn more characters.
    Once you gain 90% proficiency within a character set, a new character is introduced.
    Press and hold any alphanumeric key to hear that character in Morse code without registering a hit or miss.
    Tap the large Check or X just above the keypad to show/hide the current character. Tap and hold to see your stats.
    A similar interface is provided for Numbers, Prosigns, and CW abbreviations, both RX and TX.
    Once in one of these 3 modes you may toggle among them without returning to the main menu.
    Note that when you change modes your current hits and misses for that mode will be reset to 0,
    but overall stats are not affected.
    Remember that Prosigns are sent run-on without regard to character spacing,
    while Abbreviations adhere to proper CW spacing.
    The Copy Pad is for copying strings of characters by drawing with your finger on the white canvas.
    You are presented with a group of random characters composed of only the characters already learned,
    and you can then write down the characters as you recognize them.
    After 3 seconds, the group of characters is displayed, the Copy Pad is cleared, and a new character set is presented.
    You have the option to choose the word size from 1 to 10 characters.
    The Copy Pad works best with shorter strings. For longer strings, pen and paper are more practical.
    Please note: the Copy Pad DOES NOT attempt to recognize your handwriting.
    This app also includes a straight key transmit feature. A character is played in Morse code,
    and you must tap out that character with the code key. You need not send at 20 WPM and should use a speed that is comfortable.
    For sending fast code, an iambic key is helpful.
    You can choose to see the code you are tapping out or the characters you have learned.
    You may also turn the sound of the characters off.
    Additionally, you may replace the straight key image with the International Morse code chart.
    Tap and hold the large Check or X just above the straight key to see your stats.
    You may use a real straight key with this app by connecting it to your Android device via an easily repurposed USB mouse.
    If you seek to practice sending Morse code, please see my straight and iambic practice keys on
    Google Play or Amazon Appstore.
    10-30 WPM CW Morse code trainer apps available on
    Google Play and Amazon Appstore:
    [​IMG] [​IMG]
