customize background
Discussion in 'Community Help Center' started by IZ7UMW, Feb 15, 2011.
  1. IZ7UMW
    IZ7UMW Ham Member QRZ Page
    How do I change the background color?
  2. AF6LJ
    AF6LJ Ham Member QRZ Page
    You can only change the color scheme for your profile page.
    http://forums.qrz.com/member.php?336781-AF6LJ
    Like this.
    At the top right hand corner of your profile page is the link to the application that will allow you to change your profile scheme.
  3. IZ7UMW
    Thanks!!!!!!
  4. UA6JD
    UA6JD Moderator Volunteer DX Helper Platinum Subscriber QRZ Page
    To change the background color in your personal qrzcom page do these steps:
    1.click to Detail
    2.click to Edit Record
    3.choose Set expert options including background colors, CSS styles, etc.
    4.you will see this text
    #csbody {
    color: black;
    #calldata {
    color: black;
    #biodata {
    color: black;
    for change background color in the top part of the page add
    background-color:#ffffff; line in #csbody part of the text - for the bottom part - in #biodata
    , where #ffffff is HEX volume of the white color . For other colors check http://www.w3schools.com/css/css_colornames.asp
    With same scheme you can change color of text .
    No possible write all about background property in forum note -
    I am wrote brochure about it "BACKGROUND" - you can download it as well as other books here.
    Also you can click to any callsign in my sample list and you will see more then hundred different backgrounds
    I am add these lines to your personal qrzcom page -you need only change HEX from white background(#ffffff) and text color from black (#000000) to other one .
    More about background read here
