ad: Bamatech-1
CT-17 Sub?
Discussion in 'General Technical Questions and Answers' started by K6YF, Feb 28, 2020.
Tags:
  1. K6YF
    K6YF Ham Member QRZ Page
    Do the USB adapters being sold on ebay to utilize CI-V data replace the need for the CT-17 converter? The ads seem to indicate this but they're a little ambiguous.
    These are the ones with a 3.5mm plug on one end that goes in the radio CI-V port and a USB conn. on the other.
    tnx es 73
    Robert K6YF
  2. W9GB
    Icom developed the CI-V “serial bus” network in the 1980s.
    VERY SIMPLE to properly DIY Build with GOOD PARTS (USB Bridge to UART).
    SAVE Yourself GRIEF ... Use a Genuine FTDI FT232R - USB to Serial TTL Bridge Chipset.
    https://www.ftdichip.com/Products/ICs/FT232R.htm
    On eBay, and his Internet store, W2ENY sells a Kit of Parts.
    https://w2eny.com/usb ct17 kit/
    USB to CI-V Interface
    by Mark Spencer WA8SME
    QST Magazine, May 2007, pp 54-55
    http://www.n5dux.com/ham/files/pdf/Explore USB with this USB to CI-V Interface.pdf
    Thanks to Robotics and Android experimenters,
    off-shelf interface pieces are available & cheap.
    SparkFun Electronics (Colorado)
    using FTDI FT232RQ or FT232RL USB Bridge Chips
    DEV-09718 (cable), 5V serial UART
    https://www.sparkfun.com/products/9718
    DEV-09716 (breakout board), 5V serial UART
    https://www.sparkfun.com/products/9716
    Connecting an Icom Radio to a Personal Computer (PC)
    by AB4OJ
    https://www.ab4oj.com/icom/ic7700/7700hw_sw_setups.pdf
    Icom CI-V Interface
    by Greg Ordy, W8WWW
    http://www.seed-solutions.com/gregordy/Amateur Radio/Experimentation/CIVInterface.htm
    Simple Icom CI-V Interface
    by G3VGR
    https://www.qsl.net/g3vgr/civ.html
    CI-V Primer
    by DF4OR
    http://www.plicht.de/ekki/civ/index.html
  3. AA4PB
    AA4PB Ham Member QRZ Page
    You do not need a CT-17 when you use one of the USB to CI-V converters. The CT-17 is an RS-232 to CI-V converter. You would need a USB to RS-232 converter to connect the CT-17 to a USB port.
  4. K6YF
    Thanks to both of these replies. It gives more than enough to go on. My only prior experience with this bus was on an IC-7300 but I didn't use it much.
    Great info!
    Robert K6YF
