Convert high voltage keying to positive keying
Discussion in 'Straight Keys - CW Enthusiasts' started by VK3MTW, Aug 27, 2021.
  1. VK3MTW
    VK3MTW Ham Member QRZ Page
    Thank you have just tested that with my multi and then a test light to see better.
    Will work very nice
    Will post up my built soon.
    Thank you
  2. KG7WGX
    So, here is a sketch showing how that might work. I didn't show the internal MFJ keying circuit, but that is what completes the path to the negative side (gnd) to energize the relay.
    Cutting the factory wiring to the jack is necessary to isolate the internal relay source and the external factory jack source.
  3. VK3MTW
    Oh my excellent.
    Thank you again.
    I was in the process of drawing and sending my idea to make sure I knew what to do.
    I'll still upload my drawing so you can see what I thought from your 2nd last msg... IMG_20210829_215659129.jpg
  4. KG7WGX
    It should work.
    Whatever connector you use for the boat anchor key output should be rated for that voltage, of course.
  5. K7JEM
    K7JEM Ham Member QRZ Page
    Make sure that you place a reversed biased diode across the coil of the relay. This prevents the high voltage spike that is generated when the relay is deenergized from destroying the internal transistor.
  6. VK3MTW
    Cheers. Do I put that between both contacts on the coil contacts?
  7. VK3MTW
  8. K7JEM
    The diode goes the opposite direction. The cathode goes to the supply voltage.
  9. VK3MTW
    Will be a delay in the build as covid has shops closed.
    Thanks I will install the cathode side to the mains power.
  10. K7JEM
    Have you verified that the radio that you are attaching to has voltage on the key in excess of 70v? The transistor in the keyer should be good for that much, assuming it is a positive voltage on the key with respect to ground.
