ad: NXPsemi-1
Control a TIP121 used as a relay switch from 5V and 12V??
Discussion in 'General Technical Questions and Answers' started by 2E0ILY, Dec 6, 2018.
ad: DLSpec-1
  1. 2E0ILY
    2E0ILY Ham Member QRZ Page
    Only one of the devices, either the U3Swith its ATMEGA or the TS-590 will be connected, it's impossible to connect both simultaneously, so that's one less worry! Thanks for the reply Joseph.
    I have a diode across the relay, I have been using the box (antenna change over) with the U3S for a while, but now want to use it with the 590 and an external amp.
  2. WA7ARK
    WA7ARK Ham Member QRZ Page
    Here is how I would do it as shown in an LTSpice simulation:
    I plot the relevant node voltages and currents. I had assumed (before I saw your more recent posting) that the two drive signals could overlap. Of interest is the simulated realistic delay in the relay coil current, both on pick-up and drop-out...
    By examining V(C), you can see the snubbing action of D3. Note that the collector voltage V(C) is clamped to one diode drop above 14V.
  3. AI3V
    AI3V Ham Member QRZ Page
    I would add a couple steering diodes, one each on each of the 2 output lines.
    Rege
  4. WA7ARK
    I put steering diodes into the first (un-posted simulation). However, since the base-to-emitter voltage is clamped by the TIP121, and only goes to ~1.6V, there is no way that the 12V signal can back-feed into the ATMEGA output pin. Anyway, the OP says that both sources will never be connected at the same time....
    K7JEM likes this.
