ad: Prosistel-1
COMET CAA-500MARKII SWR/Impedance Analyzer
Discussion in 'The QRZ 25th Anniversary Trivia Sweepstakes Prizes' started by AA7BQ, Sep 18, 2018.
  1. AA7BQ
    AA7BQ QRZ Founder Administrator QRZ Page
    COMET Antenna is proudly sponsoring one of their flagship antenna analyzers. This is the real McCoy!
    Highly accurate analog cross needles display SWR and impedance simultaneously.
    Full color TFT LCD display screen provides graphic and numerical SWR along with total impedance with R and X values.
    Features:
    AUTO SWEEP MODE
    Automatically graphs the SWR on the LCD display. Choose any one of the pre-set amateur band frequency ranges and press the sweep button…in about 30 seconds the SWR graph is completed.
    MANUAL SWEEP MODE
    Choose the band, manually set the band-width you desire, then manually sweep the chosen frequency range.
    MULTIPLE MANUAL SWEEPS
    Should you want to make an adjustment to the antenna length, the position, height above ground, a gamma match adjustment, etc… you can overlay multiple manual sweep results in 5 different colors! Instantly graph and see exactly what happened after each adjustment!
    Range: 1.8 – 500MHz (including 222MHz band)
    • RF output level: 0dBm 1 mW
    • Measured SWR Range: Analog meter 1.0 – 6.0:1 , LCD display 1.0 – 9.9:1
    • Impedance measurements: 12.5-300 ohms
    • Reactance range: 0 – 500 Ohms (absolute value) 1.8 -190MHz
    • Battery indicator and selectable Auto-Power-Off timer
    • Operates up to 9 hours continuous using six AA Alkaline or NiMH cells (not included) or use an external 8-16VDC 200ma power source (DC cable included)
    • Internal trickle charger option when using NiMH batteries
    • Size: 3.5 x 7.75 x 2.65 inches (overall)
    • Weight: 2 lbs 2 oz with alkaline batteries installed
    • Available from all major Ham Radio Dealers in the US
    The CAA-500MarkII is the primary tool for any antenna adjustment or diagnostic project.
    Specifications subject to change without notice
    CAA-500 manual sweep mode
    Press the “Sweep Center” button and the analyzer automatically sweeps the entire pre-set band that you have selected, in this case the 2M band.
    CAA-500MarkII manual sweep mode
    In the manual sweep mode, the center frequency (in this case 146MHz) and the bandwidth (in this case +/- 3MHz) 143-149MHz have been set manually.
    The SWR is graphed by manually turning the frequency knob.
    Adjustments to the element length, gamma match, height above ground, location, etc… can then be made, and by turning the frequency knob a new SWR graph in a new color, is overlaid onto the original graph to illustrate the change to SWR.
    Each adjustment can then be graphed as may times as desired, in up to 5 different colors.
    WB6MMJ, WY6H, KA2RRK and 2 others like this.
  2. KC9GLD
    KC9GLD Ham Member QRZ Page
    Very nice, I need this.
    KM4BDH likes this.
  3. 9A6GEZ
    9A6GEZ Ham Member QRZ Page
    what to write must have each HAM operator.[​IMG]
  4. WA3UFN
    WA3UFN XML Subscriber QRZ Page
    Nice to have to take the guessing out of antenna building and trimming.
  5. K5KTF
    K5KTF Premium Subscriber QRZ Page
    If I win this, I will GIVE (incl S&H) someone my MFJ-259 !
    KM4BDH, KM4DNM and KA4TLC like this.
  6. K7RIK
    K7RIK Ham Member QRZ Page
    I need this and will sleep with it under my pillow.
    KM4BDH likes this.
  7. AB3TQ
    AB3TQ Subscriber QRZ Page
    I decided this unit had exactly the features and band coverage I needed, so I bought one. If you don't need a unit tied at the hip to a computer - or need long term results storage, you will not be disjointed. I really like the hands free bandsweep option that generates visual SWR charts.
  8. KE8KNI
    KE8KNI XML Subscriber QRZ Page
    Wow! Thats a great tool! It would be a blessing to win
  9. VK2CV
    VK2CV Ham Member QRZ Page
    VERY nice tool!!!
  10. KA4TLC
    KA4TLC Ham Member QRZ Page
    I would love to have it as I enjoy building Antenna
