ad: Alphaant-1
Collins 75S-3B Optional CW Filters
Discussion in '"Boat Anchor" & Classic Equipment' started by WZ6F, May 30, 2021.
  1. WZ6F
    WZ6F Ham Member QRZ Page
    Hi,
    I did a search, but maybe just missed them.
    Wondering, could someone tell me please the options I have for filling the 2 CW filter vacant positions? Ideally, I would like a solution that gives the performance (or thereabouts) without waiting and paying for the original Collins filters to become available. It just has the SSB filter option filled currently (926-9427 filter).
    Some potential questions I considered whose answers may help (feel free to consider/skip - I am sure all of you know more than I do on this receiver!):
    - Are there any currently available manufacturers selling something that will work?
    - Are there other known compatible filters out there (e.g. IF frequency, impedances, etc.) with potentially just some soldering (e.g. other Collins filters not specifically made for the 75S-3B/C)?
    - Not that I would, but is the 75S-1 filter 200Hz filter compatible with the 75S-3B with soldering it in? I have two of the 75S receivers currently (the 75S-1 and 75S-3B).
    Both of the 75S receivers I have work very well in terms of sensitivity, selectivity especially for the 75S-1 with the 200Hz filter, ergonomics, etc. Ideally, I would like to add an AM filter as well to the 3B, but need to do some research first.
    Note: I have noticed for SSB that using the receiver's rejection tuning in conjunction with external DSP (JPS NIR-12 Noise And Interference Reducer) brings the lower frequency noise down a good amount. It is worth using in some cases and will experiment more for optimal settings (especially for CW). Considering though what I heard in terms of the DSP improving CW, I definitely want to see what I can find in filling in the optional filter positions.
    Thanks for looking!
  2. WA1GXC
    WA1GXC Ham Member QRZ Page
    The Collins Collectors' Association has a website with much information, most resources open to all, even non-paying members.
    You can search their archives online --The question comes up a lot. Also, you may post an inquiry to buy, I believe, on their discussion site.
    If you haven't accessed them before , it's a great resource.
    I bought a 75S-3C (same receiver) in 1985 and acquired a new 200kHz compatible filter for CW manufactured by Fox-Tango (no longer in
    business), drop-in plug-in and supposedly electrically equivalent. It wasn't. The impedance was way-off and even with changing input and output
    capacitances in the receiver's filter circuit there's more signal path loss than there should be. If I had to do it over again I'd get the narrowest
    Collins 455kHz mechanical filter I could acquire or a real Collins OEM crystal filter. Collins left the filter business quite a while ago and you may easily
    pay $150-175 for a filter-- 1/3 the price of a receiver in good condition these days. Prices have tanked. Too many Amateurs going to Sunset Acres
    or ham heaven.
    Good luck.
  3. WZ6F
    Great response, thank you. I will check out the CCA. I am surprised that it looks like I will probably need to go back to the original filters considering what you said for which their price agrees - ie in demand so alternatives are probably hard/close to impossible to find. I do like the Collins equipment, considering the tradeoffs I care about- my station of choice. Very sad about the older Collins generation passing away. I bet a lot of us have the Elmers to which we are grateful and miss. I expect to be looking for that 200 or 300Hz filter shortly. Thanks again for the response!
    73!
    WA1GXC likes this.
